Warning exclamation in a triangle with an arrow around
Liamkel
Post by Liamkel » Mon Jun 18, 2018 4:19 am
I have this warning light that keeps flashing on my dash when I put my foot down on the motor way, a yellow exclamation mark in a triangle with an arrow around it. It does it alot over 60 mph but occasionally does it before if I need to speed up quickly. The turbo doesn't seem to kick in when the light flashes. It only started after I had a new suspension compressor put in and 4 new tyres put on. The tyres are standard, not run flat. I did some reading and it seemed that I was okay to fit non run flats on, people seem to do it quite often but after fitting them the guy did mention he had someone fit non run flats to a BMW and he changed them as he said it messed with the sensors as the suspension isn't set for non run flat tyres. Any ideas?
Re: Warning exclamation in a triangle with an arrow around
Post by Alan Gunn » Mon Jun 18, 2018 7:38 am
It is the ABS i think.
Could be the sensor or the ring on the shaft.
Liamkel
Post by Liamkel » Mon Jun 18, 2018 4:59 pm
What does that mean in simpler terms?
NehalX5
Post by NehalX5 » Mon Jun 18, 2018 5:14 pm
If the tyres aren't star marked, they do cause issues for the car. The 4WD system and gearbox does not like it, so it would throw up warnings such as this, and possible transmission noise/damage.
The symbol either means DSC or ABS issues. The DSC module can fail on these, best to take a look at that. On top of that, the ABS module/sensors should be checked.
Battery tests should be done as well, bad batteries lead to issues with electronics in general.
BMW E70 X5 3.0sd | M-Sport | 7 Seats
Audi A6 C6 3.0TFSI Quattro S-Line tiptronic
Citroën C1 1.0 VTR
BMW E39 528i SE Manual
Liamkel
Post by Liamkel » Fri Jun 22, 2018 8:14 pm
When I press the DTC button on the dash it doesn't do it? Does this shed more light on it.
Post by Alan Gunn » Fri Jun 22, 2018 8:49 pm
First thing you need to do is get a fault code scan done.
