PAG oil
- henrym3
PAG oil
Does anyone know how to clean up/remove PAG oil stains on bodywork. Is there some magic solution?
VW R32 Gone
VW R32 Gone
- snrbrtsn
Re: PAG oil
Try some Autosmart Tardis....
Whilst trade branding it’s probably one of the strongest, though most solvent based cleaners should work, though these will remove any protection on the bodywork so will require rinsing and repolish / sealing....
- henrym3
Re: PAG oil
Thank you for that, I'll try and find some
VW R32 Gone
VW R32 Gone
- henrym3
Re: PAG oil
The “tardis” arrived but it’s ineffective, still it will be handy to have. Back to the drawing board.
VW R32 Gone
VW R32 Gone
ttr
Re: PAG oil
Henrym3
For what it’s worth and not knowing how bad the stains are, have you tried a good quality panel wipe, type used in spray shops for Bodyshop repairs?
Failing that I have used old fashioned cellulose paint thinners, it wAs fine on my car paintwork but I worked quickly and patch tested first, definitely more concentrated than panel wipe.
As a fallback, or safer first try, have you tried G3 fine cutting compound, then re wax and polish.
Hope this might help
BMW X5 E53 3.0D Auto Sport 2006
- henrym3
Re: PAG oil
Thanks for that, have some G10 in garage bit less harsh but would give an idea.
VW R32 Gone
VW R32 Gone
