Hello Folks,
My 2005 E53 3.0D Manual Sport appears to have a slow oozing leak from the PS pressure hose (BMW 32416764029), the one running from the rack input, across the rack and up to the reservoir.
The leak is not at either end but where one of it's two flexi-sections has a crimp 'joint' half way along the rubber run.
Not sure what this joint does, as it's inline, has no branches and each of these flexi lengths are pretty short so it's an odd one to joint, unless it's some sort of inline pressure / flow regulator.
The question is regarding the hose replacement; new OE seems to be around £280, don't see any good 2nd hand ones at the mo, does anyone know of any other replacement sources at a reasonable price?
Richard.
	Power Steering Pressure Hose - Leak from inline crimp joint
				RChaloner
2005 (05) E53 X5 3.0D Sport 6 speed manual
2001 (X) E46 330D SE Touring manual
1996 (?) E39 523i SE Saloon
- marti
Re: Power Steering Pressure Hose - Leak from inline crimp joint
Give this chap a call, he sells new genuine BMW parts at a really reduced rate..Brian 0141 3058512....lives in Scotland parts normally arrive 2-3days... or you can try eBay.de
[quote="RChaloner"]
Hello Folks,
Richard.
I use Hydraulic hoses all the time in my job as a service engineer, take it off, (drain your power steering fluid into a suitable drain tray from the broken joint )
They will be able to remake the hose with new or reuse the ends if non standard.
£30 I suspect
Refil with dextron3 I think ( form of ATF fluid ) turn lock to lock , top up fluid , sorted
													Hello Folks,
Richard.
£30 I suspect
				RChaloner
Thanks that's an interesting idea.
Are you thinking of any hydraulics firms in particular, or just look for a service centre near me?
The metal ends & centre sections are likely to be generic sizes and barbs but probably bespoke pipe angles, so would expect a re-use is best, assuming the crimp collars can be replaced.
Thanks,
Richard.
Thanks,
Richard.
Probably best to get a photo if possible and email it to a local Hydraulic hose supplier and they will be able to advise what's possible.
- Gordon
When I needed a new pipe for my Saab I went to the nearest branch of Pirtek. They made me a new on for £25.
Gordon
						Gordon
- lezmtaylor
Yes Pirtek is the way to go.   I was a forklift service engineer and we always used them.
Also used them for hoses for my boat, Yellow pages or google.
Lez
Lez
