Reversing Camera Retrofit
Lyons
Post by Lyons » Sun Apr 22, 2018 11:33 pm
Has anyone ever retrofitted an oem reversing camera to an LCi E70? There’s not a massive amount of info on it on Google, but a couple of places suggest it is possible if the car has CIC and rear PDC.
Kufatec do a wiring loom for it, but strangely no full kit.
Is it just a case of getting said loom, plus a module and camera off eBay? Or is there more to it?
Re: Reversing Camera Retrofit
Post by X5Sport » Mon Apr 23, 2018 8:10 pm
Have a look at Realoem and see if there is a retrofit kit?  If there is then there should be an EBA reference which is the set of instructions you need to do the install.
Lyons
Post by Lyons » Tue Apr 24, 2018 6:20 am
Good suggestion, thanks. I checked last night but sadly there doesn’t seem to be an official kit.
There is the likes of this on eBay though;
https://rover.ebay.com/rover/0/0/0?mpre ... 2948915681
Lyons
Post by Lyons » Tue Apr 24, 2018 12:43 pm
Apparently that kit is an aftermarket camera, and they don’t do supply only.
gileso
Post by gileso » Thu Jul 05, 2018 7:34 am
[quote="Lyons"]
Our new (to us) 40d didn't have a camera (which we had on our previous 35d), so I contacted the Ebay seller mentioned above (OEM retrofit being way too expensive). Apparently, for an LCI with PDC, the price is around £275 fitted, but it only has static lines. An upgraded version with dynamic lines is available, but is nearly £400 fitted. The guy sounded knowledgeable, but you do have to go to Birmingham for installation.
After much research, I went for the Emtronica kit with dynamic lines (https://www.ebay.co.uk/itm/BMW-Reversing-backup-camera-retrofit-3AG-E88-E90-E84-E70-CIC-MID-1-3-5-X1-x5/262689576513?hash=item3d2984d641:g:XIYAAOSwmSdaYLN~) to self-install. Purchase was £220, and installation took about an hour - the hardest part is routing the wire to the rear camera. It works perfectly, with a clear, bright image.
I'll post a short how-to when I get the time.
Now: E70 SE 40d 2011
Previous: E70 M-Sport 35d 2009
Ducklakeview
Post by Ducklakeview » Sun Aug 12, 2018 9:31 pm
[quote="gileso"]
[quote="Lyons"]
Ooh. I fancy one of those..
Mike
2012 X5 40d - Loving it..
Z4 3.0 - With LOTS of mods  ::)
#TheZedShed
boy2k
Post by boy2k » Wed Aug 22, 2018 5:41 pm
gileso
Post by gileso » Thu Aug 23, 2018 3:24 pm
[quote="boy2k"]
Avin do one for cheap.
https://avinusa.com/bmw-trunk-release-b ... 0-e71.html
I suspect this is an add-on to the Avin head unit, as there's nowhere to plug it in on the OEM system...
