Transmission Failsafe
lezmtaylor
Post by lezmtaylor » Wed Apr 18, 2018 11:11 am
Have had this problem for a while now ,when starting the car and in Park , frequently the trans f/safe warning comes up .
The car battery is 2 years old and is fully charged (Ctec charging when parked). The initial way to make the wng light go out is : switch off ign , remove key, wait for warning to go out and try again. Some times the wng stay out, other times it take numerous times before it stays out.
Is there a wng sensor that is playing up ?
I have just tried slipping the gear shift into neutral before starting  and so far the T W L has not come on.
The warning does not come on when driving the car.
May seem a bit garbled, but have given as much info as possible.
Lez
Re: Transmission Failsafe
Post by henrym3 » Wed Apr 18, 2018 11:48 am
Difficult Lez, so many things can cause this really need a scan to hopefully point you in the right direction. Are you starting the car with the ctec still connected or are you disconnecting first. As it isn’t happening when driving i would still lean toward battery problem but really need a scan
VW R32 Gone
lezmtaylor
Post by lezmtaylor » Wed Apr 18, 2018 7:10 pm
Hi Henry,
No always removing ctek before starting the car.
Any suggestions for best code reader ?
Lez,
V8 00USH
Post by V8 00USH » Thu Apr 19, 2018 4:16 pm
You can't usually scan the gearbox ECU for codes with cheap scanners as they only scan do the engine ECU. Best off trying to find someone with BMW software or a decent commercial scanner like a Snap On etc.
I've had this on mine a couple of times too on startup but nothing has shown when I've scanned it.
Post by henrym3 » Mon Apr 23, 2018 9:26 pm
I have one of Foxwell's expensive scanners (hand held) £300+ and it scans the gearbox, been very impressed and not just because I spent that sort of money but in all honesty over the last 4 years had I went and payed for a scan I would probably have spent way more than that plus you have the convenience of the slightest problem then bung the scanner on.
VW R32 Gone
Post by marti » Tue Apr 24, 2018 9:42 am
Even though you say your battery is only 2 yrs old it can still be a low voltage problem cells do sulphate and die, check the voltage when not started should be around 12.2V or there abouts and when running 13.8V to 14.2V.
lezmtaylor
Post by lezmtaylor » Thu Jun 21, 2018 9:47 am
Well, I thought I would try and explain what I have done to cure!! the problem.
On the advise of Henry3 I bought a good code reader ( Autel Maxidiag Elite MD802) , but it did not throw up any fault codes for the Trans Failsafe).
Sod it , so I have now adopted the following start procedure which works every time.
To start : key in ignition, turn to 1st position, select Neutral with trans selection lever (gear stick) and then start car, works every time, NO Trans failsafe on panel.
I know I may be missing something, but this system works everytime, Road speed is fine( had legal limit +60)
so any ideas out there.
Battery is fine, 2years old.
Have just done 2 x 320m trips in last week, no probs.
Lez
Sky Bear
Post by Sky Bear » Thu Jun 21, 2018 8:29 pm
Maybe look at popping it into someone who specialises in gearboxes for their take on it.
Gloucester Road gearboxes in Bristol could do you a full dialysis fluid change at the same time which is always a good move with an auto box.
Or if starting in neutral works for you call it character and ignore.
SB
5.0L E53 owner who has a child like grin when driving. Hobbies include visiting lots of petrol stations. :drive:
Post by henrym3 » Fri Jun 22, 2018 2:28 pm
Feel well guilty now Lez, spending all that money and not getting a fault. Hopefully it will pay for it’s self in the years to come. Not that I’m hoping you’ll get lots of faults. I’ll stop now before I dig the hole any deeper
VW R32 Gone
lezmtaylor
Post by lezmtaylor » Fri Jun 22, 2018 7:03 pm
No Problems Henry, got another tool to play with and as it does all makes of car Suddenly I am very popular with the younger family members,  can't think why!!
Lez
V8 00USH
Post by V8 00USH » Fri Jul 13, 2018 1:55 pm
That will be your transmission position switch at fault then.  Around £250 brand new from BMW. I've recently replaced mine with a used one off an L322 4.4i M62 Range Rover (£65) as it was doing the same thing and eventually came up with the corresponding code stored on the transmission ECU.
lezmtaylor
Post by lezmtaylor » Mon Jul 16, 2018 9:39 am
Thanks for that, at least i now know what the problem is , but why no info on the codes?
Where is the switch positioned and is it difficult to replace?
Lez
Post by henrym3 » Mon Jul 16, 2018 9:09 pm
VW R32 Gone
lezmtaylor
Post by lezmtaylor » Wed Jul 18, 2018 10:04 am
Many thanks Henry, at least I have the info now printed off and in the ''to do'' File.
Lez
