Help please - Can't get in my car
hennabm
Post by hennabm » Sat Apr 14, 2018 1:35 pm
Hi all
I'm wondering if someone can PM me the way to get into my E53. It's on 02 3.0i sport.
The battery is dead and the driver's door handle carrier is broken, just to add to it.
When I first blipped it this morning it set off the alarm. That has now gone quiet and the key is not doing anything at all now.
TIA
11 3.0d X3
02 3.0l X5
82 323i
90 320i
10 116d
89 240DL
12 Punto 1.4
Reusch
Contact:
Re: Help please - Can't get in my car
Post by Reusch » Sat Apr 14, 2018 3:36 pm
Have you got breakdown cover
JFT96.YNWA
Current
Jaguar XF
Previous
BMW X5 3.0D
Spandex
Post by Spandex » Sat Apr 14, 2018 5:27 pm
I’ve read that you can get to the alternator positive terminal from underneath... If so, you should be able to get an external battery hooked up (-ve connected to a chassis ground) and get enough juice into the system for the fob to unlock it.
graemeX5
Post by graemeX5 » Sat Apr 14, 2018 5:37 pm
Have you tried entry via the boot as you should be able to unlock it with the key and then climb through
Graeme
hennabm
Post by hennabm » Sat Apr 14, 2018 5:47 pm
Hi Spandex
I take it the alternator is visible from underside then? I'll have a look tomorrow. :o
Hi GraemeX5 - mine doesn't have a key hole for the boot - not that I can see obvious. The only keyhole I can see is the driver's door and of course that doesn't work on the handle because the carrier is broken. :(
11 3.0d X3
02 3.0l X5
82 323i
90 320i
10 116d
89 240DL
12 Punto 1.4
Spandex
Post by Spandex » Sat Apr 14, 2018 6:47 pm
[quote="hennabm"]
That’s what I’ve read, but I have no personal experience. Have a look at this video, although it’s so blurry and dark it’s a bit useless...
https://youtu.be/veh1eGTWZ7M
X5-D-Sport
Post by X5-D-Sport » Sun Apr 15, 2018 4:55 pm
You-Tube  Broken bonnet release cable for the vehicle model.
In a nut-shell, one of the kidney grills can be removed from front, then a screw driver can ping the Right release latch (on RHD vehicles) & will release both latches... then open the bonnet to access the jump point at the bulkhead.
You can access the jump point under the bonnet once the bonnet / hood is up, & jumper the vehicle from another... then the fob will open the doors.
Hope this helps.
Grant B
hennabm
Post by hennabm » Thu Apr 26, 2018 5:56 pm
Hi all
Just to close this one off, firstly thank you for all the advise.
In the end a fried who is ex AA came round with his pneumatic pad and with a couple of coat hangers we sprung the OSF door.
All is good and I have stripped the driver's door ready for the new carrier.
Thanks again.
11 3.0d X3
02 3.0l X5
82 323i
90 320i
10 116d
89 240DL
12 Punto 1.4
