2005 X3 E83 2.0d Lambda problem
kampftrinker
Hi,
I have a couple of fault codes that are Lambda related, they are as follows:
Fault: Lambda probe signal virtual ground
Code: 0041F6
Fault: Lambda probe signal Nernst
Code: 0041D6
Do these codes mean the Lambda sensor is dead?
Is there anyway I can check the Lambda sensor?
I believe that there are two sensors in the exhaust before and after the DPF, is this correct?, if so how do I know which is broken?
The fault codes came from the Carly app and adapter.
Mick
Code: 0041F6
Code: 0041D6
Mick
2006 (55 Plate) X3 E83 2.0 Diesel
1993 MK1 MX5 1.6 (Summer Fun Car)
Re: 2005 X3 E83 2.0d Lambda problem
On a 4 cylinder one cat so one sensor before one after.
I'm not positive but Carly should do live data from sensors, sure someone on here will know
kampftrinker
Hi Horizon,
Thanks for the reply (again).
I've checked out the Carly parameters, the only one that stood out for me was the Oxygen mass flow upstream of particle filters. That was giving a reading of 2.79 Kg/h this was at at tickover and fully warmed up.
I've no idea if that is ok though.
Mick
Mick
[quote="kampftrinker"]
Hi Horizon,
Mick
Is the reading fairly static, tou would expect cold to warmed up the readings should be different, also I would expect a MV or volt reading.
Hi Horizon,
Mick
kampftrinker
Hi,
I'll see if I can get some more information and post it this evening.
Mick
Mick
kampftrinker
Hi,
The following information was taken from INPA for the Lambda errors. (translated from German)
Type of error: (2) Signal or value below threshold
Readiness flag: (17) Test conditions not yet fully complete
Error-statur: (35) Error currently present, OBD-debounced
MIL-status: (48) Error does not cause the warning light to light up (MIL)
P-Code: P2245 Lambda probe Nernstleitung Circuit (Bank 1, before catalyst) - low
Engine Temperature -15.00 C 63.00 C
Engine Speed 2688.00 1/min 2784.00 1/min
Suction Air Temperature 0.00 C -36.75 C
Voltage Ki 87 4.88 V 10.46 V
P-Code: P2252 Lambda probe Virtual mass control circuit (Bank 1, before catalyst)-Low
Engine Temperature -25.00 C 48.00 C
Engine Speed 3872.00 1/min 2720.00 1/min
Suction Air Temperature -15.75 C -48.00 C
Voltage Ki 87 2.74 V 10.46 V
Does this give anymore clues, the car has done 85000 miles
Mick
Mick
Am I right in thinking it is showing minus temperatures ?
kampftrinker
Hi,
I thought the temperatures were very odd, I tried looking for the live data on INPA. There were two analog pages but neither of them showed any O2 sensor (Lambda) data.
I have a friend with a Foxwell scanner that shows the live data for O2 sensors in millivolts.
I am hoping to borrow it from him in the next few days, I'll post the results.
Thanks for your help so far.
Mick
Mick
kampftrinker
Well, the Foxwell didn't give me any more information, so I've decided to just change it anyway and see if the error codes disappear.
So my next question is, what is the best way to get to the Oxygen sensor from inside the engine bay?
I looked on RealOEM and it looks line I have one oxygen sensor and two temperature sensors. I've ordered the oxygen sensor (Bosch) and the proper tool to remove it. just need to find the best way to do that now.
Mick
Mick
kampftrinker
Just changed the oxygen sensor, cleared the fault codes and went for a 10 mile drive. Read the codes when I got back and no oxygen sensor faults.
So that's another job ticked off the list, just got to get the snapped glow plug out and the fan sorted, then the car should be perfect.......
Mick
Mick
