Battery drain found but not solved
tommy2704
Re: Battery drain found but not solved
Post by tommy2704 » Mon Feb 26, 2018 12:55 pm
now sorted. it is defiantly the tv module causing the problem. when I disconnecting this alone the drain disappeared. so do I need to replace or can I repair??
tommy2704
Post by tommy2704 » Thu Mar 01, 2018 3:04 pm
it was the tv module. all working fine now. thanks for the help
marinaman
Contact:
Post by marinaman » Mon Mar 05, 2018 8:34 pm
do you chaps think this hedghog could the cause of my drain, i barely use car but after 1 week after a full charge on the ctek charger its back down to 50%  then a week later 30% when it tells me to charge it again
B&B by the sea in sunny Bridlington, best rates for members  :) www.themarina-bridlington.com
