Grinding sound
IanP
Re: Grinding sound
Post by IanP » Thu Feb 08, 2018 7:38 am
Think you need to get on touch with KKX5 on here..........
moose04
Re: Grinding sound
Post by moose04 » Thu Feb 08, 2018 6:03 pm
i had similar problem, grabbing when turning left more than right, in a straight line ok, with 4x4 light on turned out to be the abs sensor in the near side front hub, i thought the diff was going to snap it was so bad, 2006 e53
kkx5
Re: Grinding sound
Post by kkx5 » Fri Feb 09, 2018 12:06 am
Mpowerrob, my advise: change the garage. They dont know what they do. First: code from transfer, now: code from abs. E53 is a simple car. Grinding sound will be gone..for sure...4x4 light on so no 4 wheel drive, so its same as driving without vtg plug. Change the garage please...
