New dashcam being installed tomorrow
RichM50d
Post by RichM50d » Thu Feb 01, 2018 8:39 pm
I’ve been thinking about getting one for a while, so tomorrow I’m getting a Blackvue DR750S-1CH installed. Anyone on here got the 750? It seems to get good reviews.
Dogzyboy
Re: New dashcam being installed tomorrow
Post by Dogzyboy » Thu Feb 01, 2018 8:43 pm
What’s your plans for positioning and also charging it? Any clever ideas to make it nice and discreet?
RichM50d
Post by RichM50d » Thu Feb 01, 2018 9:16 pm
[quote="Dogzyboy"]
It’s one of the smallest ones on the market, so it’ll be hardwired behind the rear view mirror, so I won’t have to worry about charging it.
Dogzyboy
Post by Dogzyboy » Thu Feb 01, 2018 10:34 pm
Yeah, that’s the best kind of solution. Would you mind sticking some pics up once fitted?
RichM50d
Post by RichM50d » Fri Feb 02, 2018 7:29 am
[quote="Dogzyboy"]
Yep, no problem
kenniff
Post by kenniff » Fri Feb 02, 2018 10:15 am
Who are you getting to install it? I am tempted, but do not want to tackle the install myself as I struggle to tie my shoelaces.
Current: M50i arctic grey (G05)
Previous: RRS P400 HST, F15 M50d,F15 30d Msport, E70 35d Msport, 530i, Boxster, 330Ci Sport Vectra GSi, Chevrolet Lumina, Vxl Astras
It'll be allright in the end. If it isn't allright it isn't the end
Beefcake-2001
Post by Beefcake-2001 » Fri Feb 02, 2018 10:24 am
[quote="RichM50d"]
I have the same model installed in my X6M. Works really well , I did have the 2 channel front and rear camera
installed previously but it seemed to block out all the DAB radio signals. So I swapped it out for the single channel.
Download the Blackvue App and footage and software updates can be done from your phone.
I also have the Blackvue power magic pro installed this allows you to keep recording when you are parked up..
RichM50d
Post by RichM50d » Fri Feb 02, 2018 10:33 am
[quote="kenniff"]
There's a company in Lightwater doing it.
RichM50d
Post by RichM50d » Fri Feb 02, 2018 10:34 am
[quote="Beefcake-2001"]
[quote="RichM50d"]
I'm glad I just went for the front facing then! I was going to get the additional battery, but the 750 has a bump sensor, so will power up if the car is hit, while switched off.
Post by X5Sport » Fri Feb 02, 2018 10:48 am
For those considering a rear mount as well pay particular attention to the cable routing.  In order to avoid DAB interference (it’s due to inefficient vehicle DAB aerials which then need amplification and that signal boost then boosts everything - including the noise from the video signal on the camera cable), run any cables as close to the body as possible and along the floor.
If you can, use a metallic tape to stick the cable down against the metal body every 30cm or so.  Do not run cabling in the roof space above the headlining.  Keep the wires away from the radio system and side windows where the car aerials are fitted, if possible route down the opposite side of the car and place the camera as far away as possible.
Typical DAB installations using on glass antennas are approx 20-30% efficient and hence the amplifiers in the system.  Most manufacturers use diversity amplification now as well whenever such broad radio spectrum coverage is needed, which just makes the whole issue worse!  These amps pick up everything - including the video signal and wireless noise if that is fitted to the dash cam too.
Properly screened cabling, bonded to the chassis and making use of ferrite blocks is the best way forward for now.
The dash cams aren’t the cause of the issue, rather the use of poor aerial designs forced by designer limitations and no one wanting external antenna rods so forcing ‘solutions’ to be found that are less than ideal.
silverbeemersurfer
Post by silverbeemersurfer » Fri Feb 02, 2018 12:49 pm
Hi, I have a dashcam in my 2015 X5 3.0D M Sport, but plugged into the cigarette lighter as I am worried that it will drain down the battery if connected to a permanent feed, although the manufacturer assures me that it will shut down in power save mode, but don't want to risk it  ;).
Where / how will you connect it in the overhead console and is the feed permanent or switched?
Look forward to your pics/comments.
mogsyman
Post by mogsyman » Fri Feb 02, 2018 1:58 pm
I too have a dash cam located by the mirror.
I have run the wire along the top of the windscreen (hidden) and then down the A pillar (hidden) and then around and under the glove box (hidden) and eventually into the central armrest for power.
It switches itself off after 5 minutes of the car being switched off and to date I've had no issues.
The install itself was dead easy.
2019 F90 M5
2019 Porsche Macan
Previous
2016 X3 20D M Sport
2016 X5 M50d
F10 M5
120D M Sport
335i DCT Vert
997 C2S
30D M Sport X5
2.0D M Sport X3
535D M Sport
4.8iS X5
3.0D M Sport X5
320D M Sport Cab
996 C2 Cab
Boxster S
Golf GTi (150 D)
Pinewood
Post by Pinewood » Fri Feb 02, 2018 3:54 pm
Very similar power routing as Mogsyman. Just see the slightest bit of cable going into the centre console. Switches off after 5 mins and never experienced and low battery due to the camera.
If the X3 is in a high traffic area like a multistory, or dodgy area, then I plug it in to a battery bank which keeps the camera running for up to 7 hours.
Sent from my SM-G930F using Tapatalk
Glen
Post by Glen » Fri Feb 02, 2018 4:01 pm
[quote="mogsyman"]
Same for me took about 5 minutes to install and can't see any cables (nextbase unit)
2012 X5 40d msport Mine now gone :(
2010 320d convertible WIFE'S
2006 Mini cooper convertible WIFE'S gone
2017 X5 m50d m performance pack
RichM50d
Post by RichM50d » Fri Feb 02, 2018 6:21 pm
All done. I went for the battery pack in the end, so it’s recording 24/7. Once the car battery drops to 12V, it kicks in, then charges when you run the car. Or something like that! :D
It’s very discreet. Will post some pictures when I remember to take them! :))
