Electronic parking brake failed :(
pvr
Re: Electronic parking brake failed :(
Post by pvr » Mon Jan 22, 2018 8:36 pm
Warranty is 12 months ...
911 50th anniversary -
pcdee
Post by pcdee » Mon Jan 22, 2018 8:43 pm
[quote="pvr"]
[/quote]24 months if the part is supplied and fitted by BMW
X5 E70 3.0D SE
pvr
Post by pvr » Mon Jan 22, 2018 9:00 pm
Yep:
What is the guarantee on BMW Parts?
By using Genuine BMW Parts, you can be assured that your vehicle will be restored to the same exacting standards that it was originally created to. In addition, every Genuine BMW Part comes with a two-year, fitted parts warranty. Every one of the 20,000 components that typically make up your BMW is the product of an incredible amount of thought and expertise. Ensure that you receive and retain the best quality and performance by only replacing with Genuine BMW Parts.
Chrispy
Post by Chrispy » Tue Jan 23, 2018 11:38 am
So, and forgive me if I'm simply not reading it correctly, are the parts and labour covered?  So if it failed again within 24 months BMW would replace the part for free (including fitting) or just the cost of the part?
Admittedly the part did make up most of the cost but there was still a good £400 plus on labour after the dreaded VAT.
Black 2012 E70 3.0 XDrive M Sport.  7 seats, & tiny 19" wheels.....
pcdee
Post by pcdee » Wed Jan 24, 2018 7:45 am
I'm hoping labour too, I'll find out later today when I pick it up
X5 E70 3.0D SE
Chrispy
Post by Chrispy » Wed Jan 24, 2018 9:21 pm
How did it go? Was Labour included?
pcdee
Post by pcdee » Fri Jan 26, 2018 3:18 pm
I just got it back this morning.
It went in on Monday and got it back today!
They had some issues when installing the unit apparently.
Most importantly NO CHARGE.  I also asked about the warranty on the new part.
He said the warranty on the new part will be continued from when I first bought the faulty part.
So I got 4 months left, just doesn't seem right.
Not gonna use the bloody thing.
X5 E70 3.0D SE
Chrispy
Post by Chrispy » Fri Jan 26, 2018 3:32 pm
Wow - almost a full working week to fit it?  Just as well labour was included warranty wise! :(
Disgusting that the warranty doesn't reset when the new part goes on, but is dated from the fitting of the original.
Yep, I'm going to stop using mine too if this is going to be the case as even the new parts seem to have no design improvements, they're just imploding.
Post by X5Sport » Fri Jan 26, 2018 4:32 pm
I think the internal gearing system strips and that’s that.  It is possible to rebuild them if you can get parts, but BMW don’t bother.
snrbrtsn
Post by snrbrtsn » Sun Jan 28, 2018 8:53 pm
I can count on one finger the amount of times I’ve used mine....
Same as Auto hold, never use!
I leave the privilege to Mr MoT tester
The auto lock in Park has kept me at some wonderful angles
Chrispy
Post by Chrispy » Sun Jan 28, 2018 9:04 pm
[/quote]By the horrendous squealing grinding sound mine made when it died that would figure. Considering the fact these things are used widely on VAG's and other manufacturers these days (my wife's Q3 has one, which funnily enough has also freaked out once, but electronically, and an ignition restart got it to let go) you'd have hoped they'd be more robust.
Sent from my SM-G930F using Tapatalk
Post by X5Sport » Sun Jan 28, 2018 9:25 pm
If my Škoda Superb is anything to go by, it now has a motorised actuator on each rear calliper rather than a central actuator pulling cables driving a drum brake.  Perhaps manufacturers have learned that is a more reliable way of providing an ebrake?
Chrispy
Post by Chrispy » Sun Jan 28, 2018 9:41 pm
[/quote]Yeah the sound the Q3 makes when engaging the parking brake is clearly different, like it's winding on the rear calipers, and when I DIY replaced both my Fabia vRS calipers years ago, they both had the parking brake as a cable pulling on the calipers themselves powered by the handle in the car, usual fare. Motorise that action and you have a parking brake. My theory is they did just that rather than reinvent the wheel, and it's seemingly more reliable. BMW's with rear discs have the little drum brake thing going on for the parking brake and they went for a single central actuator and dual bowden cables from it to the drums. Perhaps it has to do more work, pulling on those cables vs a "per caliper" servo on the VAG's? I've been told the bowden cables seize (mine were welded in place apparently) and the actuator must then struggle to move them as a result. Possibly corrosion related?
As I say, my wife's (manual) Q3 did lock on and refuse to let go the other week, prior to mine imploding. It simply ignored the pressing of the button. Turn off the ignition, wait 5 mins, try again, all sorted. So even those aren't trouble free but the fix there didn't cost £1300.....
