CTEK charger question
Smeeagain
Re: CTEK charger question
What size eyelets are on the maplin leads?
- marinaman
- Contact:
im pretty sure M8 it doesnt say on their ad but ive seen it elsewhere.
B&B by the sea in sunny Bridlington, best rates for members
www.themarina-bridlington.com
- marinaman
- Contact:
looks like the app for the ctek battery sense is useless if you have ios 11 on Apple phone
no way would it connect borrowed friends Android and it works though not convinced of accuracy
it said 34% on a battery that was full charged only a few days ago
Cable run should not make any difference as those battery cables are very large. Front or back will do.
You are more likely to get a signal out from the back than the front, however radio is funny stuff and you may need to adjust it to suit your car and need to get a signal.
A Blair
Hi,
Bit late with my post but.....
I have two cteks. I use one all the time.
On the E53 I plugged my ctek into the cigar charger. The cigar lighter on my car is live with the ignition out.
Works a treat when the car is not being used.
X5 E53 2005 4.4 Sport. Toledo Blue
Things to consider.
Radio. (something in
Detail Car.
Things to consider.
Detail Car.
