Rear Entertainment retro fit
How-To articles go here.
S3RYK
Post by S3RYK » Sun Oct 29, 2017 10:13 pm
Has anyone retro fitted the original DVD player and centre monitor to their E70? (Mine’s a 2012 40d M sport)
I see that they are readily available through breakers, but wanted to know how easy it would be to fit?
Re: Rear Entertainment retro fit
Post by X5Sport » Mon Oct 30, 2017 7:09 pm
Have a look on REALOEM for the retrofit kit numbers and there should be a reference to a BMW EPA document.  Those are the fitting instructions.  If you have a friendly BMW Parts Dept they’ll either print it for you or email it.  :)
S3RYK
Post by S3RYK » Mon Oct 30, 2017 10:41 pm
Thanks, I’ve found the parts
65509166783 - monitor
And
65129243265 - DVD player
But can’t find any reference to the EPA document....
Any help would be appreciated!
sid10
Post by sid10 » Mon Oct 30, 2017 10:58 pm
Hi the rear head rest mounts are just as good sold by BMW , one has a dvd player in the other a monitor , at least the kids in the back are looking straight forward instead of lower down on the centre console , they are easy to fit and a lot cheaper !
Post by X5Sport » Tue Oct 31, 2017 6:33 pm
BMW retrofit kit no longer available (sold out) so the EBAs have gone too unfortunately  :(
They do still offer a tablet system which could be better and as said keeps them looking straight ahead at the right level.
gileso
Post by gileso » Tue Jan 30, 2018 10:30 pm
I looked into this and then found a simpler solution...
2x ipads (cheap mk1s, android tablet will work just as well) with soft cases with velcro straps (go around the headrest poles). Bought a 1TB HDD with wifi facility, loaded 300+ films/tv on it. Ipads connect to local wifi network created by HDD, browse to required film (VLC is a good app for this) and can watch whatever they want. As they operate separately, they can watch different things at the same time. £200 for ipads, £100 for wifi hdd.
Totally removable, and transportable. Probably cheaper than a full retrofit...plus you've got 2 ipads for other uses when needed...
Now: E70 SE 40d 2011
Previous: E70 M-Sport 35d 2009
Mpowerrob
Post by Mpowerrob » Sat Apr 28, 2018 10:54 am
Looking to do this as well as recently purchased a RES, I have a 2011 40d msport, will this be a simple plug and play and power lead alr day there or will I need to buy and fit a harness to get power to the RES?
mattchubb1
Post by mattchubb1 » Sun Sep 09, 2018 11:28 pm
Just wondering the same if they are a plug and play...? or if additional wiring was required?
Post by X5Sport » Mon Sep 10, 2018 6:50 pm
Given how BMW changed the way they load up vehicle wiring after the E53, you will almost certainly need additional wiring.  BMW have discontinued the official kit but you may be able to get the installation instructions from a friendly dealer parts team.
Hunt for it on Realoem using the last 7 of your VIN.  It will be under ‘Retrofittings’ and you need the relevant EBA number.
Moley
Post by Moley » Sun Sep 30, 2018 9:37 pm
Dose anyone know where to buy one of these ?
I have got one fitted in my X5 but it's not working,  just thought it might be easier to replace rather than try and repair it
Moley
Post by Moley » Sun Oct 14, 2018 8:34 pm
Anyone have any information about this to help me put a smile on my Granddaughters little face !!
