Hi is there anyone in the north east with a BMW scanner that can turn off " suspect inactive " message on the dash of my x5 or has the knowledge to install the scanner on my laptop, thanks in advance
Cheers john
Help in North east
Smeeagain
Re: Help in North east
Try this. Fully charge your battery. Then disconnect and touch the +/- leads together to discharge any static. Then go an make a cup of tea and leave the battery for at least 30 mins. Then reconnect.
Im not guaranteeing it will work bt it is often a battery issue.
Try it - you've nothing to lose but 30 mins of your time. It has worked for others. Me included.
