X5 heating fan stays at low speed and drivers door central locking fails
ChrisM1968
Post by ChrisM1968 » Sun Oct 15, 2017 8:45 am
I have recently purchased a X5 d sport 2003
The drivers door does not operate with central locking?
Also the heating fan stays at a low speed?
If anyone could help I would be most grateful
Many thanks
Re: X5 heating fan stays at low speed and drivers door central locking fails
Post by X5Sport » Sun Oct 15, 2017 9:21 am
Fan issue is likely to be caused by the Final Stage Resistor (FSR) aka ‘Hedgehog’.  Simple diy and not expensive.  Have a search for it on the Forum  :)
And :hi: to the Club  :D
MiketheMo
Post by MiketheMo » Tue Oct 24, 2017 1:30 pm
Do the other doors open with central locking? It's just the drivers door that doesn't work?
The GM3 module in the glove compartment, can fail with age leading to problems opening all the doors...
Tailgate usually still works.
2001 X5 E53 4.4i, Oxford green, pastel green two-tone leather. Owned 2017.
1999 E46 323i SE saloon, Fern Green, grey leather. Owned fm 2006
2003 E46 330ci vert, Orient Blue, cream leather, Dynavin N6. Owned fm 2010.
Post by henrym3 » Tue Oct 24, 2017 4:52 pm
With the drivers door does it lock by key, anyway first thing take the switch module out of the door and unplug the connection with the more heavy duty wires, spray some contact cleaner on and plug in/out a few times. Always worth a try, it's free.
VW R32 Gone
Smeeagain
Post by Smeeagain » Fri Nov 03, 2017 5:06 pm
[quote="ChrisM1968"]
Many thanks
Welcome. Can you elaborate on what you mean but the fan stays at low speed. Do you mean the fan that is activated within the car for internal temp. or did you mean the aux fan (which is a cooling fan not a heating fan next to the radiator) stays on when the car is at low speed. Mine (the internal fan)  is always on but at the minimum (as I always have the air con on which you should do anyway to stop the seals drying out), but you should be able to switch it off if you so desire (although i don't see why). Sometimes the buttons stick and it can be done to that. Or the FSR/hedgehog as already mentioned.
Post by henrym3 » Fri Nov 03, 2017 8:44 pm
ChrisM1968 you asked, on your first post, two questions, which 4 people went to the bother of giving you pointers as to where the problem might lay. You could at least acknowledge. If only to tell us we're all wrong.
VW R32 Gone
