Sub amp install
How-To articles ONLY go here.
BL02WAS
Sub amp install
Post by BL02WAS » Fri Feb 11, 2011 6:42 am
Question, is it okay to put switched 12v feed to remote on off of amp for remote? Only reason I ask is my car previously had an aftermarket sub installed so all wiring is left there bar the heavy gauge 12v off battery itself. However I do have a small gauge wire which I'm guessing was the switched??? But with a meter it's showing 12v ignition live and ever so slight milivoltage with power off. Is this ok to use on the remote for amp? Any help appreciated.
x555
Re: Sub amp install
Post by x555 » Fri Feb 11, 2011 7:29 am
If your unsure about that wire use the purple one from the RCM i told you about last night.You say to sub you mean to the amp right?? as this feeds the sub.
here is all you need to know http://www.youtube.com/watch?v=c0uM8FcS ... ure=relmfu
and don't forget :worthless:
BL02WAS
Sub amp install
Post by BL02WAS » Fri Feb 11, 2011 3:11 pm
Sorr, yes meant the amp. I will but tried that site you suggested and it says to take from a grey wire going into factory amp which is under the disk changer???
x555
Re: Sub amp install
Post by x555 » Tue Feb 22, 2011 7:54 am
Have you pulled your finger out and sorted this yet fella ??? if so :worthless:
BL02WAS
Sub amp install
Post by BL02WAS » Tue Feb 22, 2011 3:13 pm
dont ask!!!!!! power to tv headrests now gone!! and feed from the phono leads that were there seems to have no signal, thus no sound!! ive not got a nice warm garage to get stuck into it (yet)!! so weather permitting and with wprk its been on hold, but thinking of going to specialist tomorrow in llanelli to sort it all!!
