Shuddering........`
love154
Shuddering........`
my cousin has Just bought a 55 X5 3.0Diesel, having a few problems with the car shuddering while going between 65 - 75 mph.
I've had the tracking, balancing and wheel alignment all done but it still shudders, also happens with the cruise control on and off.
thanks
thanks
Re: Shuddering........`
What condition are the tyres and rims in? Any dents, nicks, unusual wear on the tyre treads?
What happens if you gently hold the steering at this speed - in a safe area of course - does the wheel wobble gently?
love154
There is a bit of a nick out of a rear alloy but all tyres are pretty new.
If I hold the wheel gently it shakes quite hard, tends to be worse going up or down hill.
Sounds like the balance is still off to me, unless you have a bent wheel rim.
andym3
Your discs could be warped but it may also be worth checking your wheel bearings!
Another thing to check could be your track rod ends.
CURRENT CARS - E53 X5 3.0d & E30 325I CONVERTIBLE
- x555
If the shudder is under braking then i would say discs.I have recentley noticed a shudder under braking at higher speeds and after an investigation on the weekend i need new pads and disks
.......... oh well more money more parts the car is starting to show it's mileage at the moment and has cost a small fortune lately.The price we pay to maintain our precious x's i suppose
- bullethead
[quote=""X5Sport""]Sounds like the balance is still off to me, unless you have a bent wheel rim.[/quote]
I agree sounds the same as mine and mine is a wobbly wheel..same speed aswell. Have you tried swapping a wheel at a time to see.
- x555
[quote=""bullethead""][quote=""X5Sport""]Sounds like the balance is still off to me, unless you have a bent wheel rim.[/quote]
I agree sounds the same as mine and mine is a wobbly wheel..same speed aswell. Have you tried swapping a wheel at a time to see.[/quote]
That will be them pram wheels again then
- bullethead
- Sanj
Yeap, mine are staggered and directional...
Can't swap em round.
Feel free to punch me bullethead at the Meet.
- bullethead
[quote=""Sanj""]Yeap, mine are staggered and directional...
Feel free to punch me bullethead at the Meet.[/quote]
I'm gonna print this and bring it with me........
Stick your staggered up your arses. I've got 20's and snow socks that fit all 4
And a proper engine, none of these trucks and tractor shite
- bullethead
Oh and what about the spare....Don't need to cane it for long, just enough to see if it still shakes your fillings out.
g60renshaw
I had shuddering around 60 and much more pronounced under braking. Was the thrust arm bushes. Car has only done 70K and its a well documented and common problem on the E53.
Jay
Jay
