Mystery vac pipe
Bigb
Mystery vac pipe
Hi there, just about finished changing my exhaust manifold on my 2005 3.0d and after refitting the inlet,I plugged the two plugs in the back near bulkhead and noticed there is a vac pipe coming up from the top of the autobox, is this a gearbox breather or should it go somewhere? Also I just fitted a thermostat, I have lost a bit of water, is there a specific coolant to use? It didn't seem to be any colour in particular(more like pee water) thanks bryan
- marinaman
- Contact:
Re: Mystery vac pipe
i found same pipe and was told it is a breather, sticks up like an umbrella handle.
also did thermo as only getting to 65c now up to 95c, went to local auto place and told it was a special one , had a code on the bottle made by Bluecol cant remember the code though
B&B by the sea in sunny Bridlington, best rates for members
www.themarina-bridlington.com
Bigb
Superb, thanks for that. I seen the g48 code on the search function, might just drop the lot and give the beast new coolant
