Possible boost leak
Zedhed
Possible boost leak
Got a bit of a whistle when giving it some beans.sounds like a possible boost leak to me but could be wrong.would this have possibly triggered the trans failsafe message the other night.
Re: Possible boost leak
[quote="Zedhed"]
Turbo whistle is normal for the E53, I liked it, my X3 has the same engine but I don't get the whistle, possibly muffled out by the DPF.
Transfailsafe can be brought on by a failing battery/ low voltage. Keep the battery topped up with a charger/ conditioner if it's not frequently driven , or does short journeys. Heck the voltage is over 12 volts
Or it could be a transmission problem, It try the battery first.
Zedhed
Did a test on the battery and alternator already and checked out fine.alternator is kicking out 14v plus.
What can sometimes upset these cars is quick turning of the key to start. I was led to believe that (depending upon options) there are dozens of little systems that all have to play nicely in the data buses and sometimes they have a slow day! I was advised to turn, pause for the warning lights to cycle, then crank. I used to get spurious - and scary warnings - regularly until I started doing that. Very few after adopting this approach.
A voltage drop is the usual cause the 'Transmission Failsafe' warning. Two modules not playing nicely!
Zedhed
It came on the display the other night on the way home,but next morning it was fine,and nothing else since.
