Hi all
going on jolly tommorow
fitted new thermostat today, at least i know the old one was faulty as only read 65c, so filled it, bled it,
warmed up and went for run, put the dash test no.7 on unsure what now is normal. it reading 95 to 97c , is this normal for diesel ? got home nothing boiling steaming etc. heater works fine. put my digital heat infra gun on the top hose this read 88c bottom hose was around 45 or 60 c i forgot ! anyway long trip planned so dont want mishaps, gave it some welly on test drive temp gauge sits in middle same as before when the dash computer said 65c
thanks
Quick answer please to temp
- marinaman
- Contact:
B&B by the sea in sunny Bridlington, best rates for members
www.themarina-bridlington.com
Re: Quick answer please to temp
Sounds about right based upon what others on here have found
Have fun on your jolly
Never anthropomorphise computers. They hate that.- marinaman
- Contact:
Phew a bit worried there, but will go with all you pro's advice
Tried a search but couldnt seem to find l but was in a worry mode.
[quote="marinaman"]
Coolant has a much higher boiling point than water, saying that,as the cooling system is an enclosed system it can rise higher than 100 degrees C without any problem. It's designed to run up to 110 + as per norm without any issues.
- marinaman
- Contact:
well you learn something every day. got to 55 and dozens of cars and never knew that.
