Hi all,
 I noticed my 2003 X5 3.0d had the engine oil light flickering whilst stuck in traffic yesterday..however when i got over 30 mph it stopped..then again at slow speeds it started flickering again.
 Has anyone had this issue or know what it is please?
Thanks in advance.
	Engine oil Light flashes at low speeds
				Sunnythered
Re: Engine oil Light flashes at low speeds
Is it flashing orange or red ?.
I take it you have checked the oil level.
				Sunnythered
flashing red mate, oil level checked and is ok
Low oil pressure then.
Might be worth an oil and filter change to see if that makes any difference.
Get the oil pressure tested.
Also it could be a faulty sensor in the sump.
I had two oil pressure sensor failures on mine (the first when brand new!) so that would be the first thing to check as suggested above.
