	random bongs.
				themoog
random bongs.
The wifes X5 seems to be going mad.. The check engine oil level popped up last week and it needed an oil service so I did that. Check oil level is still bonging (level is correct), check brake lights bongs (nothing wrong with them) and now the suspension inactive is bonging.. But that's ok.
Is this a battery disconnect for 30 min job?
The battery is only 18 months old and ill check it in a bit but I don't suspect it really.
Re: random bongs.
Sounds like the electrics are having a tizzy fit.  Take the battery connections off and leave for a while (touch the +ve & -VED together to kill any residual charge too.
Battery could be dying if only used on short journeys, and several members have reported Bosch (if that is what you have) batteries dying well inside warranty.. >:(
				themoog
Re: random bongs.
I'll do that in a bit. I think its a Duracell battery. I'll check.
				themoog
Re: random bongs.
12.6v across terminals so that's ok. Had it disconnected for 40min so let's see what happens..
				themoog
Re: random bongs.
Now the Chuffin remote key won't unlock it... Only the boot.
Re: random bongs.
				themoog
Re: random bongs.
Nope.. I thinks its gone to transport mode. When we first got the car the remote didn't work. I had a local BMW expert turn transport mode off and its been ok since. Unfortunately he has relocated.. I wasn't expecting it to do that by disconnecting the battery.
It's amazing how a simple thing like the remote not working feels like a massive inconvenience..how lazy have we become? The wife is gonna go mad when she finds out..
Re: random bongs.
Hmmm.  Taking the battery off shouldn't have done that, especially given the battery reset is the norm for any oddities....almost like 'take 2 aspirin and call me in the morning....'
				themoog
Re: random bongs.
I wouldn't have thought so either. I've spoke to Tim Spicer who isn't far from me and he says he will take a look.
Boot opens withe remote, doors don't. Door switch inside doesn't work- all the hallmarks of TM. What is it with these cars..
				X5-D-Sport
Re: random bongs.
I found out the other day - and recharged my spare key too...
by sitting it on a Cordless Electric Toothbrush charging base for a few hours.... worked for me & may be worth considering if you have a spare key that's not been used for ages, to keep it alive.
				Glen
Re: random bongs.
I used my spare fob the other day, when the car opened the seat went to a new setting and heater changed from the previous setting.
Must have a memory the key fob.
2012 X5 40d msport Mine now gone
2010 320d convertible WIFE'S
2006 Mini cooper convertible WIFE'S gone
2017 X5 m50d m performance pack
- Upex
Re: random bongs.
I think it's detailed in handbook Glen, how to save settings to a key, they should all do it (if set up of course)
Re: random bongs.
As long as key memory was enabled at delivery (my 2004 E53 needed to have it enabled) it will work with all of your keys.  We use Mem 1 & 2 and keys for storing His n Hers settings on all of our cars.
				themoog
Re: random bongs.
Right. Fixed. I called Tim Spicer in Duxford as he is 10 min away. He plugged in the diagnostic machine and checked for faults. He that the driver door solenoid showed a short fault. Then the transport mode was cleared and now the keys work as they should. All done for a tenner. He is my new best mate..
						- henrym3
Re: random bongs.
So presumably you replaced the solenoid or fixed what ever the short circuit was. Otherwise the next bump or pothole may induce the same fault??
VW R32 Gone
VW R32 Gone
