Phillips & Flat head screwdriver, Torx T-20, Torx T-27 for glove box, 16mm socket & Torque wrench with 6†extension for the steering wheel
PARTS REQ
HEATED STEERING WHEEL----P/N ----323-067-688-33
STEERING COLUMN SWITCH---P/N-----613-183-790-91
RELAY---P/N----61-368-373-700 ---for behind the glovebox
http://flic.kr/p/8qkjFb
thanks sanj for the help you were right already prewired
you need to fit a relay behind the glovebox about 1/2hrs work as means removing the full glovebox and then the fuse box which sits in there if you check fuse 29 and make sure there is a 10amp fuse there this means the car is pre-wired which saves a lot of time there is a small red 3 pin plug taped onto the loom under the top steering column cover if your car is prewired this connects into ypur new column switch.if the car is not prewired it can still be done but you will have to tap into a switched power supply such as the cigarette lighter and run a separate cable to the connector behind the column switch
BEWARE REMOVAL OF THE AIR BAG MUST BE DONE WITH THE KEY REMOVED FROM THE IGNITION OR YOUR AIRBAG LIGHT WILL COME ON and you will need a code reader to remove the light ,fitting of the column switch is easy just remember to connect your extra red lead ,then off with the old wheel then on with the new remember to mark your wheel so when you fit the new one on its in the correct postion nothing worse than a wheel off centre
i am impressed how hot the wheel gets it only takes a matter of seconds to heat up am well happy
hope this helps someone sorry for the lack of pics but any questions just ask and i will talk u through it seats are next all the switchgear is in
http://flic.kr/p/8qhbxD
