So for my first post unfortunately it is with a problem
The battery in my E70 died the other day
So I sourced a new battery fitted it and code the new battery to the ECU. As soon as I started the car the car came up with a load of errors most of these I could clear but I am stuck with one now showing a DTC error with the fault code 00A817.
Does anyone have an idea where to start to look for this or is this going to cost me a trip to the stealers?
Changed battery and now have a load of fault codes
allanhelen
Re: Changed battery and now have a load of fault codes
One thing you can also do is drive slowly forward and steer from lock to lock. On the E53 a battery change could trigger warnings and this was the trick to reset it.
If the suggestion above doesn't work then: Try disconnecting it, waiting 20 mins and reconnect again.
Oh and
to the madhouse
Oh and
allanhelen
Thanks that did the trick all faults have now gone
Thanks for the welcome I am a long time BMW owner but this is my first venture into the X's
