3.0 D-Sport 2004 Turbo oil feed pipe.
I have a turbo out-pipe gasket to change as its stinking the vehicle out & as much smoke comes from under the bonnet as the rear on a cold start lol...
AND
it stinks in the vehicle if stationary...
I have a manifold + a whole top side gasket kit etc to swap at the same time as I suspect there is also a crack in the manifold..
Question ???
There are apparently 2 variants of turbo that effect which oil feed pipe I need... either a Vacuum OR Electrically operated...
Without stripping the vehicle for hours... is there any easier way to work out which pipe I need to suit which Turbo ?
3.0 D-Sport Turbo oil feed pipe
X5-D-Sport
Re: 3.0 D-Sport Turbo oil feed pipe
Put the last 7 of your vin number in this site and you can search all parts and part numbers.
http://www.realoem.com/
