	Aux Fan
				Colin
Re: Aux Fan
Hi Strummer  i think i remember that on the forum some time back   did you take a search to see
			05 , 30d Le Mans Blue Sport
				strummer
Re: Aux Fan
I did minimal information
				Smeeagain
Re: Aux Fan
yep its been on the forum several times over the years. Take a look
				strummer
Re: Aux Fan
plenty of problems no info on anyone actually changing one..
				Smeeagain
Re: Aux Fan
Type "youtube remove aux fan bmw x5" into google
				strummer
Re: Aux Fan
Yes I watched them I asked about doing it without removing bumper
				Smeeagain
Re: Aux Fan
[quote="strummer"]
Your first post asked about doing it without removing the bumper, your third post asks simply for info. If there is no info on here about doing it without removing the bumper and the youtube cideo indicates removing the bumper, then that would suggest doing it without removing the bumper is either more difficult or impossible. In the absence of the i fo you want why not try and see if it can be done?
				Ryoken
Re: Aux Fan
i did mine a few years ago, nightmare it was,
I had to remove the bumper, then slide it out from underneath,
what was the kicker though is the new one I got , didn't work either, so I wasted my time , and I bought an aux fan for nothing
2002 e53 4.4  tempremental
2001 suzuki Hayabusa just for fun
				strummer
Re: Aux Fan
[quote="Ryoken"]
thanks for that mate,if I get one will plug in and try before I remove the bumper
				Smeeagain
Re: Aux Fan
And if it works you can post back in the How To section. Dont forget to take pics
				strummer
Re: Aux Fan
[quote="Ryoken"]
what was the problem in the end did you manage to sort it?
				Ryoken
Re: Aux Fan
no , it was one of them unsolved mysteries I'm afraid , I think I changed a couple of temperature sensors, I know I did one on the lower lines somewhere,  had the ac checked everything was ok , apart from it having no gas in it , so obviously got it re gassed,  the  ac worked lovely now and it has done since I had it  regassed, but the ac fan don't work ,
unless some one tells me of some thing else to change or a definite way of testing it , ill just live with it
				Smeeagain
Re: Aux Fan
no idea if this will help at all, but my aux fan wouldn't stop working. Just kept running. AC gas was low(wish) but not drastically so. Got that re-gassed and then learned that is was the AC pressure sensor switch was kaput. The sensor thought the AC was on the blink so kept kicking the fan in. Maybe the sensor is worth look? My garage tested it by hooking up diagnostics, as far as I can recall, to see ether they could 'instruct' the system to switch on the ac etc which in turn told then the ac was fine but the sensor wasn't. Not sure how/if you could test yourself
				strummer
Re: Aux Fan
I have replaced the aux fan temp sensor and a sensor in the coolant system but still not working,I may buy the fan and as I said earlier will plug in first to see if it works.
