Hi,
I have just had an RAC check on an E70 X5 sd and there is evidence of oil residue around turbo pipes.
It is an 08 plate with 56K on the clock.
According to the report..
"The underside of this vehicle is fitted with protective guards, which has restricted the inspection of the lower parts of the engine and transmission, and further defects may exist that it was not possible to visually identify.
Oil residue, as documented in this report, may indicate a potential major problem. Further investigation is strongly recommended."
Has anyone seen anything similar or could you shed any light on potential causes? I'd like to go ahead with the purchase but don't want to take on undue risk... any tips?
It is a private sale and the vendor is local to me and seems like a good guy so I don't think he is trying to hide anything.
I am planning on taking out the insured warranty when I buy it.
Thanks.
Oil Residue Around Turbo Pipes? **Ignore - posted in wrong section - Thanks**
knackeredoldman
Last edited by knackeredoldman on Sat Feb 04, 2017 10:14 am, edited 1 time in total.
Re: Oil Residue Around Turbo Pipes?
Certainly worth looking at just in case. It could be expensive if a turbo seal is heading for the scrap yard!
If the oil is spreading down the inlet side and is in the intercooler than that is more concerning.
knackeredoldman
Re: Oil Residue Around Turbo Pipes? **Ignore - posted in wrong section - Thanks**
Okay - thanks. I think I'll just have a word with the vendor and talk about how we can get it checked over. I might lose out but better that than end up with a wrong 'un.
A
A
