Can it be the tyres??
Re: Can it be the tyres??
Post by Smeeagain » Tue Jan 31, 2017 2:31 pm
Put whatever you want on your cars....
That comment is really unhelpful - a newbie looks at that,d onset bother to read the full thread and goes out and knacker the transfer box and wonders why because some guy on here told hm he could put on anything that he wants. I think what you meant to say is 'put what you can afford on your car bearing in mind the implications on other parts of the vehicle as a result of getting the tyres wrong. It's very much a case of false economy and putting on what you 'want' is very much at your own risk, because it's not necessarily going to work and could be massively costly in the long run.
Smeeagain
Post by grumpywurzel » Tue Jan 31, 2017 3:27 pm
[quote="grumpywurzel"]
What I meant is exactly that. Personally and I can feel the starting of a witch hunt brewing here but I put the best tyres on that I can. Also from reading here it seems that the X5 likes to have a complete set of tyres changed at the same time using the same make and model of rubber
Budget ior cheap tyres in my eyes on a car that weighs more than my bloody Labrador (which is a lot!
grumpywurzel
Post by Smeeagain » Tue Jan 31, 2017 3:41 pm
So my two pence worth... Replace all four tyres at the same time, shoot me if you want but it'll be cheaper than replacing the transfer box!
Well said - totally agree!
Smeeagain
Post by X5Sport » Tue Jan 31, 2017 6:28 pm
Post by dani_armo » Wed Feb 01, 2017 11:58 am
How safe is it to keep them on? The tyre fitter did say the alloys were ok to take them and I have just checked they have EH2 marked on them (the rears anyway) so I presume theres no danger of a tyre 'slipping off' if one gets a puncture and the standard ABS/stability sensors are safe enough to warn me of any air loss??
I am planning to get a set of new michelin diamaris all round at some point, but if these are ok I am happy to run with them until they need replacing
dani_armo
Post by Smeeagain » Wed Feb 01, 2017 12:53 pm
Smeeagain
kkx5
Post by Pinewood » Wed Feb 01, 2017 8:29 pm
It's all very subjective, but for me the summer setup on 19" staggered setup will have to be non runflats
Sent from my iPhone
Pinewood
Post by X5Sport » Wed Feb 01, 2017 9:09 pm
Post by Nat » Thu Feb 02, 2017 9:48 am
Just an observation from personal experience. I am aware of the RTF / Non RFT argument.
Has anyone actually suffered a puncture with a RFT tyre ?
I have.............there is far more give in that side wall tyre than you think , + of course the X5 is not exactly twiggy either.
I always thought you would need the tyre pressure monitor to tell you when you have a puncture. because you may not know/notice. I can tell you that may be the law or a EU manufacturing directive but I can also tell you you can visibly see the tyre is deflated and you can also feel it.
Of course advantages of RFT is assuming you havent got a gashed the tyre , then you can drive on it almost indefinitely if you keep stopping to re-inflate it there by saving the sidewall from damage and travel far further than the advisory 50 miles .
Just other things to consider thats all.............
Nat
Post by gavp84 » Thu Feb 02, 2017 11:41 am
I am not a fan..
Previous
1999 328i Vert
1998 328i Coupe
1997 328i Vert
1997 323i Coupe
1999 Golf Gti turbo
1989 320i Coupe (first car)
gavp84
Post by Smeeagain » Thu Feb 02, 2017 1:15 pm
I had RFT Tyres on my 123d, had a puncture and tried to drive 6km home and after 2km it split I had to pull over and get recovered!
I am not a fan..
That's disappointing, but I believe quite unusual, hence the name runflat. If the OP is considering runlflats then Id ask the fitter what the manufacturers advice is on their ability to be run flat.
If I recall correctly when they were first introduced it was more a case of being able to continue to drive safely until you could bring the car safely to halt, as opposed to the car skidding all over the place, and they weren't (originally) meant to be run any significant distance, although I'd expect more 2k out of them !
Smeeagain
Post by X5Sport » Thu Feb 02, 2017 6:16 pm
Drove several miles home with no issue, had it fixed and ran it for another 4 years.
Post by Nictrix » Thu Feb 02, 2017 7:04 pm
It was a front tyre and something ripped the sidewall.
She said she could feel there was something not right and there was the warning on the dash.
She called me and I told her to drive it home slowly which she did and made it fine, around 8 miles.
The next day she drove it around 15 miles to get the front tyres swapped and alignment done.
The garage showed her that the wheel had a slight buckle ,that they fixed, which may have been caused by hitting potholes with a flat tyre.
In this instance the runflats were a saviour as she would have been stuck otherwise on the motorway in the middle of the night.
Pricing quality tyres there didnt seem to be much of a difference between runflats and non runflats in 20" sizes so in this vehicle I would stick with runflats.
Nictrix
Post by X5Sport » Fri Feb 03, 2017 5:49 pm
Return to “General X5 Forum (E53 1st-gen, 2000-2006)”
- Forum
- ↳ Forum Discussion
- ↳ New members section
- BMW X1
- ↳ General X1 Forum (F48 - 2nd gen : 2015+)
- ↳ General X1 Forum (E84 - 1st gen : 2009+)
- BMW X2
- ↳ General X2 Forum (F39 : 2018+)
- BMW X3
- ↳ General X3 Forum (G01 - 3rd gen : 2017+)
- ↳ General X3 Forum (F25 - 2nd gen : 2011+)
- ↳ General X3 Forum (E83 - 1st gen : 2003+)
- BMW X4
- ↳ General X4 Forum (F26 - 1st gen : 2014+)
- BMW X5
- ↳ General X5 Forum (G05 4th-gen, 2018+)
- ↳ General X5 Forum (F15 3rd-gen, 2014+)
- ↳ General X5 Forum (E70 2nd-gen, 2007-2013)
- ↳ General X5 Forum (E53 1st-gen, 2000-2006)
- ↳ Problems (sub-forums for all models)
- ↳ Problems (F15 3rd-gen, 2014+)
- ↳ How-To
- ↳ Problems (E70 2nd-gen, 2007-2013)
- ↳ How-To
- ↳ Problems (E53 1st-gen, 2000-2006)
- ↳ How-To
- BMW X6
- ↳ General X6 Forum (F16 2nd-gen replacement, 2014+)
- ↳ General X6 Forum (E71 - 1st gen : 2008-2015)
- ↳ Problems (sub forums for specific models)
- ↳ Problems (E71 1st-gen 2008-2014)
- ↳ How-To
- BMW X7
- ↳ General X7 Discussion (G07, 2018+)
- General
- ↳ General car-related discussion
- ↳ Gallery
- ↳ Meets/Events
- ↳ The lounge
- ↳ On the light side
- ↳ Other Marques
- ↳ Buy and sell
- Links
- ↳ Z4-Forum
