	Cold Start Issues (update 24-02)
				Colin
Re: Cold Start Issues
WOW  £15 each  and maybe a controller  plus labour ...
			05 , 30d Le Mans Blue Sport
				Smeeagain
so six plugs is £90 (for the labour involved don't do some of them do them all), and the controller from ECP was about £80.
I think, but I might be making it up, the labour was a bit over £200.
				grumpywurzel
Don't you just love the X5  :-[
			2005 X5 3.0d Sport
 and a new Gearbox :'(
				Colin
Im going out in an hour so ill go switch on the webasto   i guess ill keep using this for the winter
guts a £400 for glow plug issue
Love the X5 it just keeps taking ... still i wouldn't dream of changing it
Got a price for hand made fully fitted cat back S/Steel with quad round tips or big ovals by powerflow here in N Ireland £370 not to bad i thought ?
				grumpywurzel
Yeah that's a steal Colin. Especially as its a powerflow one.
			2005 X5 3.0d Sport
- jonnyivy
Colin,...just to let you know that I was having your problems too only a month or so ago,... I changed all 6 of my "faulty" glow plugs only to have them tested once the new ones were installed and every one was perfect condition !!! It was when I heard about the controller/ module/(whatever its called) could be faulty I took off the plugs leads one at a time and took the readings with a multi-meter during the supposed 'pre-heat' period. The readings were all over the place with at least 3 reading zero !! I changed the module with a wee bit wiggling of wires and hoses from under the inlet manifold and now it starts first time AND without the wee puff of white smoke from the exhausts on start-up. (un-burnt diesel) I did change the battery a week before hand to 900 cold crank Exide battery too..... incredible differance from the old woaw.....woaw.....woaw... woaw...woaw....woaw.... woaw.......woaw......  lol
Hope this helps on your way..
Jonny
Jonny
Virgin owner of X5 3.0 D 2003 ( getting to know her better now )(thinking of a long-term relationship now )( sadly  now divorced !! )( 4 years later...met the newer model and happy again )
				Colin
Thanks Jonny  the X is up for MOT in Feb so will get mechanic to work his magic
Colin..
			Colin..
						- Insight G40
Well been so busy not got round to sorting this.
Had the battery tested today, making an unhealthy 384CCA.
Had alternator tested and making a healthy charge rate with pretty much no reduction under maximum load.
New battery next week should undoubtedly sort it.
E53 Sept 2006 3.0D Sport
