Small bang when reversing around a corner
x5e53
Post by x5e53 » Wed Jan 04, 2017 10:11 pm
I hear a slight bang and a small judder when I reverse whilst turning the wheel.
Even on a flat surface (so no kerbs etc.).
Usually happens when im reversing to the right.
Any ideas?
Re: Small bang when reversing around a corner
Post by Horizon » Wed Jan 04, 2017 10:21 pm
http://xdrivers.co.uk/forum/index.php/t ... l#msg83309
Is it similar to this thread.? Unfortunately there wasn't a resolve posted.
Post by Alan Gunn » Thu Jan 05, 2017 7:04 am
[quote="Horizon"]
Wiper upgrade ??.
Post by Horizon » Thu Jan 05, 2017 6:09 pm
AW8
Post by AW8 » Fri Jan 06, 2017 11:43 am
Hard to tell if driveline or rear bushes.
Once warmed up do some kickdown acceleration from standstill or 30 mph. If you get a thud then it could be rear subframe bushes.
If noise is metallic only engaging reverse it might be auto box related.
x5e53
Post by x5e53 » Sat Jan 07, 2017 11:53 pm
No noise on kickdown. Only when in reverse. Even then, not 100% of time, only when reversing while cornering/turning.
Very strange. Will get all bushes checked and diff oil checked/changed. Assuming diff oil can be changed in a 4.8is, some units are marketed as 'sealed for life'.
Steamyrotter
Post by Steamyrotter » Mon Jan 09, 2017 1:20 pm
Are you sure you haven't knocked someone off their bike???
(Surprised someone hasn't suggested similar yet....)
(not surprised i did though!!!)
There is also the possibility of the rear Handbrake shoes binding and or releasing in reverse,,,
Might be worth getting the disc/drums off and checking the internals and shoes for debris and adjustment etc...
Please note...
spartacus
Post by spartacus » Wed Jan 11, 2017 8:40 pm
[quote="x5e53"]
Very strange. Will get all bushes checked and diff oil checked/changed. Assuming diff oil can be changed in a 4.8is, some units are marketed as 'sealed for life'.[/quote]
Ignore the 'sealed for life' line. Audi quote that too on the rear diff on Quattro models. If it's approaching 100k or indeed exceeded that, then by all means drain and refill. Always open the filler plug before dropping the drain plug in case it's seized. Stuff will come out like Mellow Birds. Check for swarf just in case.
Use correct specification gear oil to refill and don't exceed quantity or you could burst the driveshaft seals.
2012 B8 (2012) A4 2.0 TDI Allroad  ::)
