Hidden menu question.
Riggie
Post by Riggie » Sun Sep 04, 2016 10:55 pm
I have tried accessing the hidden menus as outlined here:http://www.scoopz.com/m5board/E60_Hidde ... ctions.pdf
However, when I enter my totalled up chassis numbers, I can't get in. My chassis number is 292960, which by my reckoning comes to 28. Do I ignore the 0 on the end or do I have to add something?
Riggie
Re: Hidden menu question.
Post by Riggie » Thu Oct 13, 2016 4:45 pm
Has anyone done this on their E70?
pcdee
Post by pcdee » Thu Oct 13, 2016 8:57 pm
This does work.....I've used it mine many times.
X5 E70 3.0D SE
Riggie
Post by Riggie » Tue Oct 25, 2016 12:24 am
[quote="pcdee"]
Do you mean the E60 instructions above? I've tried it and can't get in hence my question about the
chassis number combination. Any help would be appreciated, thanks.
DiscusbT
Post by DiscusbT » Tue Oct 25, 2016 2:48 pm
I can only add that it worked on my e61, and it works on my f25. You do have to get the timing and sequence exactly right otherwise it doesn't work. Logic would suggest that if you have a 0 in the number that is what you add.
