Re: New calipers (more help needed please)
- deepblonde
What does a rolling road brake tester show the brakes are actually doing? What performance is actually being delivered by each corner? Is it balanced across each axle? Is it correctly balanced front/rear?
I haven't had my X5 on a rolling road brake tester, I should look into whether anyone down here has such a thing;
The thing is , like Dan it's only the slight increase in pedal travel that's a problem- once it engages- full braking power is there, I'd be very surprised if one or more of the brakes weren't effective.
X5 3.0d Sport, 2006 LeMans Blue, Six-Speed ZF auto, Panoramic roof, Intravee II, Navigation, etc...
OK. UK cars get put on a rolling road brake tester every year to get their 'warrant' - I think you call it - MOT Road Safety test for cars aged over 3 years, so most garages have such a tool for checking brake efficiency and balance. Does the warrant check not do the same for you folks?
Could be a piston sticking momentarily perhaps when you apply the brakes, and then 'catching up' with the fact the pedal has been applied?
- deepblonde
I'm in the State of Victoria, no MOT or anything like that, your car an be 100 years old and you don't have to get it tested, (unless you sell it privately, then a mechanic has to say it's roadworthy.);
I don't believe it's a piston stuck 'on', it could be a calliper piston retracting too far when releasing brake pedal; then the pedal has to take up the slack when you reapply the brakes (pad knock back), I haven't excluded that possibility- but it should disappear ( I think) with time as the pads wear down; there is also a slight hiss when I first apply brakes, that makes me think the booster is somehow faulty...?
Dan .... where are you ?? if your local you can have a go of mine .....
X5 e53 3.0 2002 with LPG
That's very kind of you. I'm in Sale. Whereabout are you?
2004 E53 3.0D Sport
2016 F25 X5 35D MSport
wirral .....not a million miles away
Re: Re: New calipers (more help needed please)
[quote="ianst0028"]
A bit far unless I happened to be passing though. Thanks anyway. It's going back in tomorrow anyway.
2004 E53 3.0D Sport
sorry to raise an old thread but i thought i'd share this
while replacing all the vacuum pipes on the x5 a couple of weeks ago i replaced the non return valve for the servo .... I've just noticed today that the brake pedal doesn't do that slow creep to the floor that i described before
- deepblonde
[quote="ianst0028"]
Thank you for the update;
Do you know if replacing the pipes was part of the solution; or just replacing the check valve fixed the problem?
Where did you buy the check valve from?
bmw call it a sucking jet pump ....... its the check valve on the manifold
i got it from the local dealer but it wasnt cheap (although is anything ever cheap from the dealer)
- deepblonde
[quote="ianst0028"]
I've looked it up and found this part number 16111184932,
But I'm having trouble visualising where it is,
could you please post a pic of it installed in or on your motor?
mine is a 3.0 petrol it'll be different to yours
