Anybody changed Brakes (pads and discs) recently?
max
What's the currently preferred OE spec pad/disc combo? Pagid or other?
I can't remember who makes the BMW pads, I'm sure my last set of BMW pads said Pagid or Jurid on the back but I'm not sure who makes the discs?
I'm presuming using Pagid pad and disc combo should be fine if not buying BMW pads and discs?
(For e53 3.0 D Sport)
X5 D Sport
some of my old toys gallery
Raj
Re: Anybody changed Brakes (pads and discs) recently?
I'd still say Jurid or ATE would be my choice.
Steer clear of Pagid.
max
Hi Raj
Hope you and the family are well
Is that Jurid pads and ATE discs combo? I think that combo came up when I did a forum search
X5 D Sport
Raj
All good thanks. Hope yours are too.
Yeah ATE discs with either ATE/Jurid Pads. Should be a good combination and not silly money.
Smeeagain
[quote="max"]
Hi Raj
Be interested to know what price you get for that combo - is it all four corners or just two. BTW I have Eibach discs and Pagid pads warped the discs (more than once. had to get the discs skimmed - long story see my other posts), but basically switching back to OEM discs direct from BMW caused the problem to go away
Raj always makes good recommendations
Hi Raj
Raj
[quote="Smeeagain"]
[quote="max"]
Hi Raj
Thank you buddy very appreciated.
I found out like you that Pagid aren't great and warp discs like a hot knife through butter. Plus they squealed really badly too.
[quote="max"]
Hi Raj
pcdee
[quote="Raj"]
Hello Raj
Would those makes also apply to the E70?
Hello Raj
X5 E70 3.0D SE
X5-D-Sport
Raj... sent you a PM ... if you're lurking
Dan1502
There are often decent prices available for genuine discs and pads from Cotswold or BMMiniparts
2004 E53 3.0D Sport
2016 F25 X5 35D MSport
Raj
[quote="pcdee"]
[quote="Raj"]
Hello Raj
Yes should be.
[quote="Raj"]
Hello Raj
Yes should be.
Raj
Yup sent you a text buddy.
Raj
[quote="Dan1502"]
Agreed. Sometimes the dealers offer good packs for vehicles over 7 years old or something.
max
Thanks for the replies chaps.
BMW offer a 'value line' pad packs incl sensor wires for front and rears (which I have been told are exactly the same as the pads you buy in the non 'value line' versions except for price.) I used these on my last change and had no issues what so ever.
This time round it looks like the discs will need changing as well as the pads all round. Unfortunately BMW don't seem offer 'deal packs' on the discs.
A quick scout on line shows ATE pads/discs/sensors available from ECP and Carparts4Less. Jurid pads only available from GSF.
A few places have the Brembo pad and disc combos but I'm not sure if these will offer anything more over the ATE pad/disc or ATE disc with Jurid pad combo, except knowing I've got Brembo brakes on O:-)
I'll decide on one of them tomorrow unless anybody else has any feedback
X5 D Sport
Osprey
Just changed my pads over to Brembo via Eurocarparts. Discs are fine (OEMs 2 yr. old) and the pads with the online discount code, F&R, came to £67. I know price shouldn't be an issue for braking but I thought Brembo would be a good safe bet. So far, so good.
Le Mans 3.0d 2006 - Ours
BMW 5 Series M Sport 2014 - Mine
Toyota MR2 Roadster 2004 - Wife ::)
BMW 4 Series Conv (luxury) 2016
Toyota Aygo X-Clusiv (it's a long story)
BMW X3 (F25) X-Line 2.0d (A nice combinatio
- ianst0028
I did my rears with ferodo pads and national discs at first ..... when the rears warped i replaced them with ferodo discs
the fronts i changed for ferodo discs and pads and i've had no problems with them at all
X5 e53 3.0 2002 with LPG
