2 Questions: Music Folders on USB Stick and Tuning New DAB Stations
sharpharp
Post by sharpharp » Tue Mar 01, 2016 11:15 am
Hi all,
Anyone know how to read Music Folders on the F25 X3 via USB STick?
I've got a few folders with different styles of songs on a memory stick, but the I-drive system will only read the MP3 songs in the Root of the memory stick.
I don't want to import the songs into the internal storage, I just want to play them direct from the USB stick.
Even cheap portable MP3 players have the ability to transition folders.
Secondly, how do you do a scan for NEW Dab Stations? There has been a few new national radio stations launched in the past few days, which I can receive fine at home on a Portable DAB player by doing a SCAN.
How do you do a scan for NEW DAB stations on the X3 F25? I checked in the menus, the station doesn't appear in the list and I can't see any SCAN for NEW options...
Pinewood
Re: 2 Questions: Music Folders on USB Stick and Tuning New DAB Stations
Post by Pinewood » Tue Mar 01, 2016 1:54 pm
If you have formatted the drive correctly with default partition, then it should look something like this ...
RodHB
Post by RodHB » Tue Mar 01, 2016 3:03 pm
I copied my iTunes library onto a USB flash drive which is easy to do using a computer. Works/worked really well on all my iDrive cars.
sharpharp
Post by sharpharp » Tue Mar 01, 2016 5:24 pm
[quote="RodHB"]
So did you have folders in the root of the USB drive and it lets you play tunes in them? If so, how do you traverse the folders?
I copied the folders from a computer as well, but my I-drive only sees the MP3s in the root of the USB drive
RodHB
Post by RodHB » Tue Mar 01, 2016 8:02 pm
No folders as such just copied everything into the USB (root I assume?)
Pinewood
Post by Pinewood » Tue Mar 01, 2016 8:58 pm
Try formatting usb stick and select "default partition" for the file size.  Are you using a windows 7/8/10 computer.  If that doesn't work, try a different make of usb stick.  I use a kingston traveller 101 (16gb)
Post by Horizon » Tue Mar 01, 2016 9:22 pm
Can't you convert the songs to MP3 format via iTunes or windows media? Or have I miss understood the question.
I havnt got DAB radio in the car, but have it in my van, there is a search button that searches all available channels that are in range. Make sure you are in a good reception area before you do the search
sharpharp
Post by sharpharp » Wed Mar 02, 2016 10:10 am
Thanks for the replies, but so many replies going completely off track (pardon the pun).
Forget iTunes, I did not mention iTunes at all.
For simplicity sake, on my computer I have two folders containing MP3s. If I copy both these folders to a memory stick and then use them in the car, I-drive does not allow me to go into the folders. If the MP3s are in the Root of the USB stick, then it will read them.
I want to keep the folders, because it allows me to pick and choose my mood of music by choosing which folder I go into.
But this feature which is available on the cheapest of mp3 players isn't on a bmw???
Pinewood
Post by Pinewood » Wed Mar 02, 2016 3:06 pm
It is very much available and working on my X3.  I can't help thinking you need to try another usb stick.
Also don't copy the 2 folders over.  Instead create 2 folders on your usb and drop a few music mp3's into each one as a test.
Pinewood
Post by Pinewood » Wed Mar 02, 2016 3:08 pm
Also try starting the car and then inserting the usb drive. There have been reports of some cars not picking up the drive correctly.  Just a thought.
bluestreak56
Post by bluestreak56 » Fri Apr 22, 2016 2:38 pm
RE the DAB issue, like you I was trying to find a way to tune. I found that absolute 80s the station that has moved for me as two entries now.. (one named old and one named new). Presumably they auto-tune as stated in the radio ads?
sharpharp
Post by sharpharp » Fri Apr 22, 2016 5:50 pm
Update:
Tried around 10 different types of memory sticks, same issue. It only plays tunes in the Root of the USB stick, any mp3s in a folder in the USB stick do not get picked up.
Tried formatting USBs in FAT/NTFS etc etc, still no joy.
Puzzling
Pinewood
Post by Pinewood » Sat Apr 23, 2016 7:31 am
That is very strange.  I think a chat with BMW, next service time is in order.
Re DAB STATIONS,  i found saving your favourite ones, and then programming one of the 8 pre sets to show "saved stations"  works best.  I press number x and all my favourite stations are listed.
brandon888
Post by brandon888 » Tue Jul 19, 2016 4:57 pm
where did you plug your usb ,there is one inside the glove box and one inside the armrest ...
you should use the one underneath the armrest . and go into thesetting as defaut and then it should read your usb
litany
Post by litany » Wed Jul 20, 2016 11:23 pm
USB format FAT32 only, doesn't matter how many folders and subfolders are inside. Direct play via USB in armrest.
DAB stations shows automatically once they available on region.
