Morning all,
Has anyone suffered from this problem before:
I have the 16:9 Sat Nav. Everytime I take the key out and lock the car it loses all the settings - Time etc..
Also If i do not put the key in the ignition i do not have any power to the screen/cd changer or dvd for the sat nav disk.
I have checked all the fuses but to no avail..
Any ideas? I am assuming it does not have a constant power supply which i would have thought it needed?
Here's hopefully
Simon
16:9 Sat Nav
Re: 16:9 Sat Nav
Post by Colin » Fri Jul 15, 2016 10:38 am
Hi Simon mine used to go blank or flicker think it didnt shut down properly and then battery went flat too unreliable took it out and replaced it , did you try a search on the forum im sure this will have been a topic many many times , good luck .. Colin..
05 , 30d Le Mans Blue Sport
Colin
Re: 16:9 Sat Nav
Post by Sparsons2016 » Fri Jul 15, 2016 11:05 am
Hi Colin,
thanks for the reply. Yep searched the forum and no luck!!
really really annoying!
I am tempted to rip it out but have seen thats not simple either!
How did you find it? was it expensive?
Sparsons2016
Re: 16:9 Sat Nav
Post by Colin » Fri Jul 15, 2016 12:50 pm
When changed to IPhone 6 no connection ( bluetooth , music etc ) was missing some work related calls so took it to an ICE installer agreed on an Alpine head unit INE-W997D , AMP , 4 SPEAKERS and a small sub , it ended up expensive , but i love it , sounds amazing , + voice control for everything
Colin
Re: 16:9 Sat Nav
Post by Moments » Mon Aug 01, 2016 5:45 pm
It seems like part of the system is losing one of the power lines. I know from doing a retrofit install on my E46, and fixing my current E53 screen that there's a rats nest of cabling here...
WDS says Fuse 75, 5A looks to be the power to the monitor - worth double checking. This connects to pin 7 on X18801 - see if that is hot.
Thereafter, I'd be looking for bad connectors and maybe damaged cables. A friendly who can swap monitors - even from an E46 or E53 (you don't have to fit it to the dash, just connect it) - might be helpful.
Moments
Return to “General X5 Forum (E53 1st-gen, 2000-2006)”
Jump to
- Forum
- ↳ Forum Discussion
- ↳ New members section
- BMW X1
- ↳ General X1 Forum (F48 - 2nd gen : 2015+)
- ↳ General X1 Forum (E84 - 1st gen : 2009+)
- BMW X2
- ↳ General X2 Forum (F39 : 2018+)
- BMW X3
- ↳ General X3 Forum (G01 - 3rd gen : 2017+)
- ↳ General X3 Forum (F25 - 2nd gen : 2011+)
- ↳ General X3 Forum (E83 - 1st gen : 2003+)
- BMW X4
- ↳ General X4 Forum (F26 - 1st gen : 2014+)
- BMW X5
- ↳ General X5 Forum (G05 4th-gen, 2018+)
- ↳ General X5 Forum (F15 3rd-gen, 2014+)
- ↳ General X5 Forum (E70 2nd-gen, 2007-2013)
- ↳ General X5 Forum (E53 1st-gen, 2000-2006)
- ↳ Problems (sub-forums for all models)
- ↳ Problems (F15 3rd-gen, 2014+)
- ↳ How-To
- ↳ Problems (E70 2nd-gen, 2007-2013)
- ↳ How-To
- ↳ Problems (E53 1st-gen, 2000-2006)
- ↳ How-To
- BMW X6
- ↳ General X6 Forum (F16 2nd-gen replacement, 2014+)
- ↳ General X6 Forum (E71 - 1st gen : 2008-2015)
- ↳ Problems (sub forums for specific models)
- ↳ Problems (E71 1st-gen 2008-2014)
- ↳ How-To
- BMW X7
- ↳ General X7 Discussion (G07, 2018+)
- General
- ↳ General car-related discussion
- ↳ Gallery
- ↳ Meets/Events
- ↳ The lounge
- ↳ On the light side
- ↳ Other Marques
- ↳ Buy and sell
- Links
- ↳ Z4-Forum
