"Bricked FRM" read this IF you are planning to code your car.
moggyboy
Post by moggyboy » Tue Jun 14, 2016 1:59 pm
No I didn't know what it was either!
After reading the Code X5 post I thought I would have a go at doing my mirrors using the Carly app.
The Code X5 post points out that you have to alter two ECU's the CAS and the FRM.
I did the CAS ok but then got a severe warning when I did the FRM saying don't do it but if you think you know better enter this over ride code and the buck then stops with you.
That was enough to panic me so I gave up and checked out the drama.
Here is what Carly says.............
http://support.mycarly.com/knowledge-ba ... g-frm-ecu/
I'm surprised from what Carly says that others haven't come across this?
Has any one?
Mpower
Re: "Bricked FRM" read this IF you are planning to code your car.
Post by Mpower » Tue Jun 14, 2016 2:52 pm
I'm assuming it's on a e70 if so when I coded mine not with Carly software  never had any issues maybe you I-level is out of date?
moggyboy
Post by moggyboy » Tue Jun 14, 2016 5:14 pm
I-level??
Mpower
Post by Mpower » Tue Jun 14, 2016 6:18 pm
Car's software level.
