Removing Passenger and Drivers seat
x5e53
Does the battery need to be disconnected in order to remove the passenger and/or drivers seat?
- Sanj
Re: Removing Passenger and Drivers seat
Nope - just don't turn the ignition on until all the connectors are re-attached, otherwise you'll get the airbag light on the dash.
cooa99
Just wondering .....
I am planing to buy a Front Passenger seat to replace the driver's seat due to worn sidewall since it is impossible to get a driver's seat in a very good condition.
I take it that it is easy to swap the passenger seat on to the driver frame without issues?
Current Cars BMW 2005 X5 3.0d ; Golf 2003 1.9 TDI for the High Miles Journey to work
- Sanj
Are the bolsters the same for both seats? I haven't checked.
It will be fiddly but any things possible. Remember to take lots of pics and do a 'How To'.
cooa99
it kind of looks the same. will double check again ...
And my thinking is that it makes economic sense for bmw to use same seat on different frame, but what do i know!
chrisn7
You will finish up transferring your replacement seat covers onto the original divers seat frame. This because of the seat belt anchorage point, which makes the seat frames handed. Doing this will also avoid having to re-route the seat harness.
Remember to disconnect the battery, as the seat belt mounting has wiring to it that is linked to the airbag system
