3.0 petrol oil leak
strummer
3.0 petrol oil leak
Hi all
My X5 has an oil leak,both sides of the engine are dry,I can see oil in the pan under the engine and it is dripping from the plastic cover underneath,any ideas for likely suspects?
thanks
thanks
themoog
Re: 3.0 petrol oil leak
Oil filter housing gasket probably. Difficult to see. Fairly easy to replace.
strummer
Is this where it attaches to the engine, gasket failure?
strummer
seems a bit of a mission to replace looking at how to's on youtube
Slick
Common on the 3.0 petrol engine is a blocked breather pipe, if you have no history of it being recently changed it would be advisable to change the pcv valve ( breather) and all its related hoses too.
my first X5 was a 3.0 and the breather was blocked and the dip stick tube where the oil return connected to it was blocked too, causing the cam cover gasket to leak, worth checking the dipstick tube too
Jaguar F type
X5 4.4 facelift
Vauxhall Vectra diesel daily driver
X5 4.4 facelift
strummer
Where is the pcv valve,what's it like to replace?
Slick
Its under the front of the inlet manifold and its a tad fiddly to change , Oh and its called a CCV valve on this video.....
https://www.youtube.com/watch?v=E3ve7S8sZcI
Jaguar F type
X5 4.4 facelift
X5 4.4 facelift
strummer
cheers for the replies I may look at taking it to the local indy to get looked at
strummer
Ccv valve was blocked and oil filter housing leaking at join to head sorted by local indy
