BMW scanner 1.4
evoblue
BMW scanner 1.4
Post by evoblue » Fri Jan 21, 2011 11:44 pm
I have been watching this forum for a while since buying my X5 3.0d Manual 05 facelift. Lots of good information passed around.
Getting back to the point. I have just bought the scanner after reading some information about it. What I wanted it for was the aux heat function. Works a treat now. I did fit the remote also.
Question is is there any other people got the scanner and have done anything that is useful. I thought you could program the seats to move etc. Possible just not found this menu yet.
I stay in Fife and if anyone wants this done give me a mail.
Thanks in advance
ChewingBacca
Re: BMW scanner 1.4
Post by ChewingBacca » Sat Jan 22, 2011 12:16 am
I have used one. Here is what I remember.
Tv in motion.
Beep when locking and unlocking.
Remove cold bulb check to remove errors with LED lights.
fenj66
Re: BMW scanner 1.4
Post by fenj66 » Sat Jan 22, 2011 8:43 am
i bought one in december and added aux heat/tv in motion/flash indicators on alarm activation/changed parking sensors distance alerts.
however! i bought mine on ebay from a seller called amar_87 and after new year it stopped working. i have contacted the guy and sent it back for repair but to be honest, the communication from the guy is awful. i still havent had it back or heard anything.
seeing as how these scanners are getting more popular now, i wondered if anybody else has had issues with theirs or this seller?
x555
Re: BMW scanner 1.4
Post by x555 » Sat Jan 22, 2011 10:22 am
I 've had no probs with both of mine :lol: :D but i will let you know if anything occurs :thumbsup:
I must say that when buying it i was a bit weary of the seller who had some iffy feedback to say the least but knowing both you and Lez had purchased from him and having used Lez's previously i used the same seller and am happy.......so far at least!
Waka
Re: BMW scanner 1.4
Post by Waka » Sat Jan 22, 2011 4:27 pm
I've just got mine this week and haven't used it yet.
Just trying to get the drivers to work in Win 7 (32-bit). Anyone else managed this or have I got to find a laptop with XP on?
Curr. - Silverstone II F85
Prev. - E70 4.0D M Sport
ChewingBacca
Re: BMW scanner 1.4
Post by ChewingBacca » Sat Jan 22, 2011 5:36 pm
I used it under Vista, should be OK with W7. If you struggle you could always try compatibility mode.
Right click the BMWScan140.exe/properties/compatibility tab/run as XP
Waka
Re: BMW scanner 1.4
Post by Waka » Sat Jan 22, 2011 6:14 pm
Thanks, got it working now.
Just got to work out what the hell i do with it! :lol:
swipe
Re: BMW scanner 1.4
Post by swipe » Sun Jan 23, 2011 5:53 pm
Guys does anyone have a link for the scanner might invest in it, my peake tool doesn't give live readings so would be nice to see how my big girl E53 4.4 runs :driving:
fenj66
Re: BMW scanner 1.4
Post by fenj66 » Sun Jan 23, 2011 6:01 pm
heres a link for the one i bought;
http://cgi.ebay.co.uk/BMW-Scanner-1-4-0 ... 064wt_1141
he's based in slough, but not the fastest communicator if things go wrong, although promised to send me a replacement on monday. we shall see...
swipe
Re: BMW scanner 1.4
Post by swipe » Thu Jan 27, 2011 6:47 pm
Thanks for the link I admit I have been a bit of a tight arse and gone for 1 from china "hope its not a bad mistake" but as this was nearly £30 cheaper thought It might work. If its any good I may sell my peake tool we shall have to wait and see!!
Re: BMW scanner 1.4
Post by X5Sport » Thu Jan 27, 2011 7:29 pm
Do you need any other bits, or just the scanner for the E53 and E46 (facelift), both 2005 build? Has anyone tried it with Windows 7 64-bit? It's what's on the laptop so it should be OK in 'XP' mode too. Works with our old XP printer drivers which are all 32-bit.
Waka
Re: BMW scanner 1.4
Post by Waka » Fri Jan 28, 2011 6:55 pm
swipe, mine was a cheapy from Chine too (£49 delivered and it turned it quite quickly).
It works fine although it seems to differ from some on here in that it doesn't have any leds on the main plug.
X5Sport, mine came with the main plug, usb cable and small CD with the software on, so you don't need anything else. I don't have any problems running it on my windows 7 32-bit laptop. I don't need to run it in compatibility mode so it might run on 64-bit as long as the drivers install, which I'm not sure if they will.
nujon
Re: BMW scanner 1.4
Post by nujon » Fri Jan 28, 2011 8:11 pm
[quote=""fenj66""]i bought one in december and added aux heat/tv in motion/flash indicators on alarm activation/changed parking sensors distance alerts.
seeing as how these scanners are getting more popular now, i wondered if anybody else has had issues with theirs or this seller?[/quote]
Forgive my ignorance fen66 - but what do you mean by 'added aux heat' w.r.t. use of the scanner?
fenj66
Re: BMW scanner 1.4
Post by fenj66 » Sat Jan 29, 2011 12:53 pm
if you have a webasto heater fitted under the bonnet you can add the aux heat function to control it to the computer screen in the dash. Similar.to the aux vent function only hot air.
nujon
Re: BMW scanner 1.4
Post by nujon » Sat Jan 29, 2011 1:21 pm
[quote=""fenj66""]if you have a webasto heater fitted under the bonnet you can add the aux heat function to control it to the computer screen in the dash. Similar.to the aux vent function only hot air.[/quote]
Thanks fenj66 - probably a daft question but how do you tell if such a heater is fitted (location, appearance etc.)
