Hey
I am new to this forum so am looking for some help.
Today I fitted a reverse camera to the BMW one for which I had to remove the rear number plate lamp which I done and wired the new light and camera all in and all works fine but now I have a message come up saying I have a plate light out is there a way of getting rid of this?
Reverse camera
Re: Reverse camera
Is the new bulb an LED? If so it won't be pulling enough current for the car to detect, it then throws an error. If it is an LED, you need to get a CANBUS error free version (cheap enough on eBay). If it isn't, I've no idea.
Sent from the dark side by the power of the force!!
Re: Reverse camera
Unfortunately I can't find a canbus one.
This is the reverse camera I installed
http://m.ebay.co.uk/itm/Car-Rear-View-R ... nav=SEARCH
I have read somewhere that the 1.4.0 software can turn off this light is that true?
Re: Reverse camera
Yes you can turn off the numberplate bulb check with the BMW Scanner 1.4, I've done mine.
(SOLD) 2006 BMW E53 X5 3.0d MSport 20" OEM Rims
20mm Spacers | LED Interior Lights incl NPlate | HID kits | M-Tech Steering Wheel | LED Angel Eyes | 2016 Maps | Digital TV | Upgraded AMP | Engine Remap | LED Tails | LED Side Repeaters | Subwoofer |
Re: Reverse camera
that looks like the same camera i installed.
i fitted mine next to the number plate light so didnt need to recode the car.
Re: Reverse camera
Does this come up on the sat nav screen when you select reverse? also how is it wired in?
Re: Reverse camera
[quote="robsey29"]
It's all been covered before. Use the search facility and look for reverse camera install.
