is the seat-belt warning light supposed to flash or stay on until you actually put your belt on ??
mine does neither .... it comes on when you turn on the ignition for about 5 seconds then goes off
Daft Question
- ianst0028
Daft Question
X5 e53 3.0 2002 with LPG
grumpywurzel
Re: Daft Question
never noticed tbh, think mine does the same. Think there is some sort of time delay built in
2005 X5 3.0d Sport
and a new Gearbox :'(
- chubbs
Re: Daft Question
If you drive off without a seatbelt on you get an audible reminder. The light you see when you switch the ignition on is just part of the testing process. If all is well the light goes off. If it stays on, or it comes on at any other point, you have a problem.
- ianst0028
Re: Daft Question
how about if it doesn't make a noise when you don't have your seat-belt on ??
** i'm terrible for forgetting to put it on **
- Steamyrotter
Re: Daft Question
Seat belt warning can be coded out (and hence back in)
Perhaps someone has turned it off!!
Usually kicks in after 10mph (ish) and after you have covered a short distance
If you manage Edinburgh to Bristol with no seat belt or warning then maybe it isnt right!!!
Please note...
Please note...
- chubbs
Re: Daft Question
Try testing it with an unbelted passenger, both in the front and in a rear seat - driving on a private road, of course. Sounds like Steamyrotter may be correct, but it's worth a try.
- ianst0028
Re: Daft Question
[quote="Steamyrotter"]
Wirral to Stonehenge ......does that count* ???
i'm now assuming that its either coded out or faulty
*not really ....other half nags me about it within a mile or so
- Steamyrotter
Re: Daft Question
[quote="chubbs"]
.......Sounds like Steamyrotter may be correct......
Doesn't happen very much!!
[quote="ianst0028"]
Bit on the cusp there!!!!
lol..
[quote="ianst0028"]
lol..
Please note...
Please note...
