Switched Live
x5e53
Switched Live
I know there is a fuse box above the glove compartment.
But which wires from this fuse box location can I use for positive and negative switched live?
I need to hook up my dash cam.
- chubbs
Re: Switched Live
I know I'm not answering your question, but I just plug mine into the cigarette lighter socket (remembering to remove it before I leave the car, because the socket's permanently live). It's convenient and I can occasionally leave it on if I want to record what's going on in front of my car for a short time, in my absence (did you see the video of that guy's Aston Martin getting keyed?).
x5e53
Re: Switched Live
Yes your right, didn't answer my question
I was thinking of experimenting with a small battery connected to the switched live.
So when the car is on, the battery is being charged and working the Dash Cam.
When the ignition is off, the dash Cam runs off is smaller battery for however long it lasts.
- Richard137
Re: Switched Live
My dash cam is hard wired into fuse box at glovebox.
2006 BMW E53 Titanium Silver (Facelift)
Remapped
LED Angel Eyes
LED Reverse Lights
B-Pillars Wrapped in Carbon Black
Rear Wiper E70 Conversion
Winter Wheels (18" 255/55).
------ To Do ------
CREE Driving light set.
Steering wheel to be Carbon Wrapped.
Running Boards to be polished.
Remapped
LED Angel Eyes
LED Reverse Lights
------ To Do ------
Re: Switched Live
Use a meter and find which ones switch on.
Never anthropomorphise computers. They hate that.- crash
Re: Switched Live
i removed the crappy non working bmw torch from the glove box and removed the guts from it then soldered the dash cam power supply wires straight the the torch terminals and ran the cable out the torch bulb hole.
When plugged back into the charging point in the glove box you have a switched live providing well over the 1 amp a dash cam will require. will get some pictures if interested in seeing.
Makes accessing a switched live easy and whole camera can be removed very easily.
- Richard137
Re: Switched Live
I want to do the same for the rear' can anyone please advise/show fuse box as to what/where I can put the dash cam?
Remapped
LED Angel Eyes
LED Reverse Lights
------ To Do ------
Remapped
LED Angel Eyes
LED Reverse Lights
------ To Do ------
Re: Switched Live
Never taken the rear one out. Same trick should work and use a piggyback fuse. Puts a connector in place of the current fuse and you plug the original into that, but it also has a second fused connection. No additional wiring as it's all done from the front face of the board. No need to take anything to bits.
x5e53
Re: Switched Live
[quote="crash"]
Yes I was thinking of this, but was wondering if the torch was a switched live or permanent.
Now I know, its switched. Cheers
chrisn7
Re: Switched Live
[quote="x5e53"]
You don't need to do this - there are units specially designed for dashcams, which allow the camera to remain on when the vehicle is parked, until such time as the vehicle battery voltage has fallen to that you have selected on the special unit - search 'dashcam parking'
TheHerd
Re: Switched Live
Slight deviation off topic, any recommendations on which dashcam to buy?
I need one for my X5...
2006 BMW E53 X5 4.8is Le Mans Blue
Purchased Dec 2025, work in progress...
(SOLD) 2006 BMW E53 X5 3.0d MSport
20mm Spacers | LED Interior Lights incl NPlate | HID kit | M-Tech Steering | Upgraded AMP | Remap | LED Tails | LED Repeaters | Subwoofer |
- chubbs
Re: Switched Live
[quote="TheHerd"]
Depends how much you want to spend. I've had a cheap one for about 2 years now and it suits me fine. It's almost identical to this one - https://www.amazon.co.uk/E-PRANCE-Novatek-Dashcamera-Recorder-G-sensor/dp/B00IPDDAME/ref=sr_1_1?ie=UTF8&qid=1461396895&sr=8-1&keywords=dashcam+e+prance
They seem to have gone up in price since I got mine - think I paid about £30. There may be cheaper ones out there and there are definitely more expensive ones.
I must say I wouldn't drive without it on - it's great to know you can re-live those near misses. Other people are such bad drivers.
Re: Switched Live
I have both a RoadhawkHD and a Nextbase 512G. If you want it to be of use evidentially it must be a full HD camera system with both location (GPS), time (ideally also GPS derived) and speed data watermarked into the video trace metadata.
TheHerd
Re: Switched Live
Thanks guys.
I've also seen a NuviCam which is both a dash cam and a Sat Nav?
Any thoughts, as I do need both but from experience combos generally compromise one of the applications.
Re: Switched Live
Not seen those before....looks an interesting idea. The NuvïCam is now called the Drive Assist so beware of buying an old model!
