E70 3.0D rear tailpipes
bn16mostin
Hi all i have a 3.0D 2008 with standard round exhaust tailpipes and would like to fit the bigger m oval pipes, Does anyone know where i can buy these with pipe already on them so i can just clamp them on. Cheers in advance.
boy2k
Re: E70 3.0D rear tailpipes
The official version needed welding until 2010 and also requires bumper cuts, paint. Later versions are 'cut and clamp' replacements but still needed bumper cuts and paint.
bn16mostin
Brilliant many thanks.
- Wipeout
The OEM clamp on kit is as per the attached, I fitted this last year, easy to do, you need to cut the existing tip as per the instructions, pop out the bumper insert that's there for the standard tip and clamp the oval ones on.
- Wipeout
I've got the BMW fitting PDF instructions if you wanted to take a look.
bn16mostin
Hi yes please i would love instructions and also where did you buy the tips from..email if needed is martincarz@hotmail.com many thanks.
- Wipeout
E-mail sent bud.
Sidneyjames
How did u get on with this?
Thinking of doing the same...was it easy enough to do?
- Wipeout
It's easy to do, I used a mates exhaust cutter, basically a big pipe cutter, cut the existing pipe tips off as per the instructions, pop out the bumper insert to enlarge the hole and clamp on the new oval tips.
Sit
Any pictures of the before and after of this from anyone?? I do like the square shaped tail pipes but also accept it's quite an expense just for different tips!!
Like to see the comparison of before and after on same car though.
Si
Si
2010 X5 30d M Sport Carbon Black | Camel Leather, 20's | HUD | Shadowline | Privacy | CIC iDrive | Adaptive Drive | Pro Nav | Loudspeaker Audio | High Beam Assist | Enhanced Bluetooth | Media Pack | Bum Warmers!
- Wipeout
This any good?
Sit
I think something went awry......... ::)
Sit
Thats better - they look really good a vast improvement I would say. Did you do them yourself? Was that the OEM kit you purchased?
Cheers for the pic
Si
Cheers for the pic
Si
