Had the check low beam warning so I replaced the bulb this morning. Still have intermittent Check park lights! Checked all the bulbs, all look fine. Connections look good as well. Thought that I might try clear the fault using my scanner. I've uprgarded my software to Windows 10. Need the drivers?
Read the previous posts on the "check park lights" still not sure in the cause!
Does anyone have any ideas please?
Bought from halfords:
GE 85122 D2S HID Bulb x 1
Scanner, Windows 10 & Check Park lights
- cameronrobyn
- fenj66
Re: Scanner, Windows 10 & Check Park lights
when i have replaced a blown bulb on mine, the dash warning message goes out permanently the next time the ignition is turned on. never had to clear codes with the scanner to clear the dash warning. although there is a record in the shadow memory of the bulb failure until cleared away.
sounds like you may have a bad contact somewhere, my nearside angel eye bulb sometimes shows an intermittent fault. its a bad contact on the plug - if i wiggle it it comes on again and dash warning goes away.
mikem
Instructions here to load drivers for any Windows.
Loaded it myself on Tuesday for W10 64bit.
http://forum.e46fanatics.com/showthread.php?t=942966
[quote="cameronrobyn"]
Sounds like you've disturbed a connection whilst changing the headlight bulb as said. Good chance it's on the same headlight cluster but the front marker bulb. Maybe worth taking the bulb out and cleaning the connections.
As said above
As said above
- toonarmy
Had the bulb problem on mine pain in the but turned out to be the holder that the bulb sits in vibration for some reason then voltage made it fail two new holders for BMW cheap and never flickered
X5 e53 3.0d 53 plate and Honda vtr1000 fun time
- cameronrobyn
Thank you, it's a lose connection. Played around with the connector and the fault has gone, either that or to took an age to reckognise the bulb had been changed.
Side note, took it to BMW to have a look and they came back saying the near side low beam had gone as well! W don't have a bulb in, do you want to order one? It will be £176!!!!!! Hold on a minute it worked perfectly about two minute ago. Turns the engine on, puts lights on. It works. That mistake nearly cost me a few quid. Morale of that story........
They aren't called 'stealers' for nothing!
