Hello all
As the title says.
Had her out of a service which included glow plugs, glow plug controller, egr thermostat and oil change.
Probably not related but after a couple of days I pulled up and pressed the park button and 'bing' the warning appears in yellow.
I can clear the fault and used the handbrake but every so often it will come back.
Parking brake failure
pcdee
X5 E70 3.0D SE
Re: Parking brake failure
Sticky cables, or actuator unit, worn shoes. Could be any of them.
pcdee
Okay.... I'll start with warn shoes and check brake fluid, then move on
X5 E70 3.0D SE
Lamby
Same problem here. Did you have any luck sorting it?
pcdee
[quote="Lamby"]
BMW job in the end.....needed a new actuator. The gears has broken, they are plastic!
X5 E70 3.0D SE
- kjb1
how much?? the part was £800 ish on its own if I remember correctly
Sent from my iPhone
Sent from my iPhone
pcdee
[quote="kjb1"]
Sent from my iPhone
Just shy of 1k
Sent from my iPhone
Just shy of 1k
X5 E70 3.0D SE
