Thoughts on this front suspension arm kit?
Dimsum
Post by Dimsum » Mon Feb 29, 2016 8:45 am
I am getting wobbles under vibration and it looks like it's time to refresh the front suspension.
Found this Meyle kit on eBay and wondered if anyone has used this seller?
321748357241
Cheers!
Greydog
Re: Thoughts on this front suspension arm kit?
Post by Greydog » Mon Feb 29, 2016 10:38 am
I did the front and rear with Meyle kits from ebay on the front I was given the tip of making sure the suspension is under load when you tighten everything up. Apparently if the suspension is unloaded/extended and you tighten up the main bolt on the reaction arm when it is loaded it twists the bush causing premature failure.
I did mine on ramps which gave enough room to work with the wheels on.
Dimsum
Post by Dimsum » Mon Feb 29, 2016 3:06 pm
Thanks for the tip! Are you happy with the quality of the items? I normally use lemforder.
I don't have much space to do it myself so my local mechanic will be doing it for me. :)
