How often do you change key fob battery?
99ron
Re: How often do you change key fob battery?
Cant tell you whats wrong but fob battteries in mine last about a year before the comfort access starts to play up and I replace it. Did the indie defo register the 95a battery when it was replaced? Assume no related fault codes showing up?
3.0SD E70 M Sport.
Z4MR E85
Z4MR E85
celica
Pretty sure it's all registered
No fault codes on battery as I went back today today to check
celica
After doing some reading it sounds like Comfort Access, keys, increased battery drain has quite a lot of posts on google with faults and issues
