Grille painting
Grille painting
Has anybody tried painting the standard e83 grille?
I was contemplating painting it to resemble the titanium version.
Any tips for removal, and what the best colour paint match would be??
Sent from my Nexus 10 using Tapatalk
Re: Grille painting
I would have thought that as long as you got it really clean and then gave it a very gentle rub down for a 'key surface' then a coat of plastic primer followed by titanium silver spray should do it?
Getting it really clean will be important and you might want to use something like Isopropyl Alcohol to wipe it down before spraying to make sure any dust and grease etc is removed. There are no doubt items such as 'tack wipes' from car paint places - or Halfrauds - that will do just as well.
Re: Grille painting
Thanks for the reply.
My main concern was that the silver paint had to be exact, but glad to hear that it may not be the case.
I take it the slats do not release from the frame?
Re: Grille painting
You should be able to find an 'exploded' diagram on Realoem which might help.
Re: Grille painting
[quote="barachello"]
To remove from memory:
Open bonnet
Remove the plastic cover above the grilles (i think it was 4 tore screws)
Then very gently with an old credit/aa card slide it around the tabs to release the grilles
Open bonnet
2011 BMW X3 30d M Sport
Re: Grille painting
Thanks for that
Will have a look at Realoem, and see how it goes
- jonsteele
Re: Grille painting
If they're anything like F15 grills, the slats are glued to the chrome surrounds.
Sent from the dark side by the power of the force!!
Re: Grille painting
Do the titanium grilles have a matt finish or gloss ?
In the process of painting mine now, but need to know whether to lacquer them or not ?
thanks
thanks
Re: Grille painting
thanks
The slats are Matt and the surround gloss
thanks
Re: Grille painting
That's great, thanks for that.
I have painted the grilles tonight, so will leave them to dry overnight and see how they turn out.
Sent from my SM-N9005 using Tapatalk
