E70 X5 - Heaters not working
x5e70d
Post by x5e70d » Fri Jan 08, 2016 2:49 pm
HI Guys, the x5 heaters wouldnt blow any air from the heaters at all?
all the functions / buttons all work fine as do the controls but theres just no air?
any ideas?
thanks in advance
libra007
Re: E70 X5 - Heaters not working
Post by libra007 » Mon Jan 11, 2016 2:26 pm
Looks like very common issue, I noticed the same issue before buying, apparently it was fixed by replacing FSU attached to blower, but I now have annoying rattling noise coming
2009 X5 MSport
celica
Post by celica » Mon Feb 15, 2016 12:05 am
What's fsu
I have an annoying resonance humming and pulsating noise which I think is related to the electric blower
If I turn it off it stops
Maybe the fan inside the climate control causing it and at times makes a high pitch noise too
Post by X5Sport » Mon Feb 15, 2016 5:40 pm
I think you mean FSR.  Final Stage Resistor.  If it fails either nothing works or the fans won't switch off.
OP:  Check the fuses in case one has gone.  Is there nothing even in 'Auto' with recirc off or in Auto? Recirc shuts off all outside air.
TomX5
Post by TomX5 » Tue Feb 16, 2016 11:49 am
Sounds daft and something you have probably checked already, but I had the same thing with my car. I only had a tiny bit of air coming out of the front vents with the blowers on full whack. I had the climate set to blow air fully out of all the vents; foot-well, front and windscreen (again I'm sure you've checked this) but the real difference was made when I turned off the blowers in the center console that blow to the back seats.
Might be worth a look.
celica
Post by celica » Tue Feb 23, 2016 7:59 am
I've posted on main area with details of blower regulator and blower unit
Apparently BMW parts sell a lot of these in a month
About £100 for regulator and £200 for motor fan
