F25 Spare Wheel kit
- Pinewood
F25 Spare Wheel kit
Does such a thing exist? I would love to buy one and take on especially long journeys. I had one for my E60 and used it twice, having replaced the RFT's for normal tyres.
Re: F25 Spare Wheel kit
Look on Realoem and you should find the part numbers. Look on line and hopefully save yourself some money.
Never anthropomorphise computers. They hate that.- Pinewood
Thanks for the tip. I checked Realoem and found this part number 36112187043, but it's ridiculously expensive. For circa £4-500 I can buy a 17" wheels and use them as winter/spares
Now you know why BMW = Breaks My Wallet!
mikesmith2939
I have an extra wheel for my E83 but it does not fit in the carrier, so stuck with the space saver
- Pinewood
We don't have a dedicated storage space, so it has to fight for space with luggage, or stay at home for emergency use
RodHB
On my F25 I carry the Emergency Wheel Kit that I bought for my E61.
My garage checked that it would fit but thankfully I've not had to use it - touch wood!
- Pinewood
Daarn, i let my kit go with my e60
Are you sure it fits? I would put it on to be sure one weekend and let me know please. They can be bought relatively cheaply nowadays.
RodHB
Yes I think so - we tried it out when I got my first F25 3yrs ago?
If my ageing memory severs me right - I'd bought a set of E83 winter wheels (which wouldn't fit) and tried it out then whilst it was jacked up at the garage?
If not I've been carrying it for nothing. [emoji3]
When I get the chance I'll check it out again just to be sure?
- Pinewood
http://www.xdrivers.co.uk/forum/index.p ... msg#131872
Could you give me the tyre size in full please.
My car has 245/45/19 and 275/40/19 tyres, which gives a rolling diameter of 703mm. As long as it's the same (+/- 1%),it should be ok.
RodHB
Your tyres are the same as mine.
The wheel fitted OK with no binding with the brake discs.
Emergency space saver wheel with tyre set comprises:
1x Black steel emergency wheel 4BX17 ET:18 (36 11 6 758 778)
1x Rubber valve L=42,5MM (36 12 1 116 326)
1x Tyre Continental CST17 T135/80R17 102M (36 12 6 758 795)
- Pinewood
Thanks for checking, but that won't work in a real life scenario
Difference in diameter:
245/45/r19 and 135/80/r17 is...
8.49%Actual diameter change: 55mm
That would cause an issue with your transfer box.
We need a total diameter pretty close to 703mm or a 2% max difference
RodHB
I would have to do the maths but would they work with 17" wheels?
- Pinewood
http://www.tyresave.co.uk/tyresize.html
plug your spare wheel and actual wheel sizes into here and get the definitive answer
- Pinewood
The 17" wheels come with 225/60 tyres which equate to a diameter of 702mm so the spare you have will not be suitable.
I've decided to keep a look out for a single wheel and tyre to keep at home (spare)
